cars smoking alot......
just got done putting my turbokit on and cars smoking alot and sounds like it open header with the open downpipe,like its a n/a application....i didnt put a fmu on,but have the hondata on and a fpr and gauge is that fine?,need a few answers.....also took my car for a spin and wouldn't give power past 2500k,almost like it loses power after 2500....??????need answers...
Re: cars smoking alot...... (spoon20)
Check your oil return line just had the same problem on one we just put togeather. The line was not flowing good enough changed and no more smoke. needs tobe pretty big line and bung in the pan.
cars idling at 60 on the fpr gauge...is that normal....the good damn turbo sound like a loud muscle car...thinking its sorta strange...????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon20 »</TD></TR><TR><TD CLASS="quote">cars idling at 60 on the fpr gauge...is that normal....the good damn turbo sound like a loud muscle car...thinking its sorta strange...????</TD></TR></TABLE>
you check all your hoses and lines?
Re: cars smoking alot...... (bubbahatch92)
you need to get larger injectors to be able to not run the fmu. If you try to run your car on stock injectors with no fmu your going to blow it up. a fuel pressure regulator is not a substitute for an fmu .How much boost are you trying to run?
Sounds like you're running WAY too rich.
Check the hondata basemap. Make SURE that the injectors are set to stock. If they are, your fuel pressure is probably set at STOCK which is 42 (in the hondata). If so, you're dumping a bunch of fuel.
Turn the fuel pressure on your car down to 42 and see how that works.
Yeah, turn the reg down to 42. Make sure the injectors in the hondata are set at stock.
You set up the base correctly right?
GForceInteg
06-06-2005 01:19 AM
