car wont start
Old Nov 27, 2007 | 10:41 AM
94hatchvx's Avatar
Default car wont start
the timing is right the distributar is right and im getting spark. the motor had jumped timing when i was pulling it out of the garage for the first time and so i retimed it. it fires but on on one cylinder. bent valves? idk wut else to do
Old Nov 27, 2007 | 11:36 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: car wont start (94hatchvx)
I don't see how this topic is related to FI...
How do you know the car is only running on one calender? Did you pull plug wires or injectors? Normally with bent valves the car will be extremely loud or not run at all. Have you tried turning the crank with the plugs out? Stock ECU? Stock injectors? You need to give us more info.
Old Nov 27, 2007 | 11:39 AM
i my honda
Global Mod
Yeah, I'm guessing you have an electrical problem...
https://honda-tech.com/zerothread?id=2145785
Old Nov 27, 2007 | 04:06 PM
JaredKaragen's Avatar
Default Re: car wont start (White Smoke)
<U>What motor</U>??????
are you sure your wires are hooked up correctly?
is the motor timed?
Are you SURE it is timed?
Now; when it "Won't start" does the CEL ever go out?
Old Nov 27, 2007 | 05:58 PM
94hatchvx's Avatar
i fixed the electrical problem, it was a faulty ground. the car is a b16 turbo. when i crank it over it just fires once each full rotation. then i feel the manifold and the only runner that is warm is the number three cylinder
Old Nov 27, 2007 | 06:00 PM
boostedcivicsir's Avatar
Mr. Badwrench
how bad did it jump time?
if it was bad, a comp test and leak down are in order to check for bent valves.
Old Nov 27, 2007 | 06:01 PM
Inliner's Avatar
well if your sure its timed right get out the compression tester... you prolly pwned your valves...
gohonda
May 12, 2019 05:44 PM
JDM_SOHC
23
Sep 27, 2011 04:02 PM
2ltrtodd
Jan 23, 2008 12:18 PM
wannab20hatch
13
Dec 3, 2003 04:22 AM
bambam
Nov 19, 2003 12:44 PM
