Boosted car not starting Map Sensor
Old May 28, 2008 | 04:51 PM
Akalima's Avatar
Default Boosted car not starting Map Sensor
K just wondering if the MAP with prevent a car form starting. I have a 99 gsr turboed. The wires r good, fuel pump works, injectors are getting power, the dizzy is new. The car will turn over but will not fire and the iac will start buzzing. I am using a piggyback computer but im thinkin if that were toast the car would still start but run rich. So im left with not enough fuel pressure of map im thinkin.
Old May 28, 2008 | 08:11 PM
hybridsol's Avatar
Default Re: Boosted car not starting Map Sensor (Akalima)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akalima &raquo;</TD></TR><TR><TD CLASS="quote">K just wondering if the MAP with prevent a car form starting.</TD></TR></TABLE>
No. It will prevent it from idle-ing. Is it throwing a code? Sounds like you have the plugs mixed- I think they are the same (3-pin round)
Old May 29, 2008 | 05:43 AM
Akalima's Avatar
Default Re: Boosted car not starting Map Sensor (hybridsol)
No codes. It was running in oct. then wouldnt start again. What do u mean 3pin?
Old Jun 1, 2008 | 08:08 AM
Akalima's Avatar
BUMP
Old Jun 1, 2008 | 09:34 PM
akira712's Avatar
map and tps use the same connector so its possible to mix them up
Old Jun 2, 2008 | 01:23 AM
JaredKaragen's Avatar
your MAP sensor will have these 3 colors:
Yellow/Green [or Yellow/Red]
Black/White
White
This way you can know which is which.
Old Jun 2, 2008 | 06:57 AM
cpierich's Avatar
Just had that same problem. I tried everything and it turned out to be the coil. I know you said you have a new dizzy but i was under the impression i did too. Just a thought...
Old Jun 2, 2008 | 12:13 PM
champLSinteg's Avatar
Default Re: (cpierich)
Yes. the map sensor can make it not start. A buddy of mine had the motorola 2.5bar and somehow one of the legs broke off flush to the sensor. It would not start at all. He disconnected the 2.5bar and hooked up the stock map that was still on the tb and luckily I had a chip with from my previous tune with the same size injectors on the stock map. It fired right up and was able to cruise it home.
Old Jun 2, 2008 | 04:03 PM
Akalima's Avatar
Default Re: (champLSinteg)
I know its not the coil. It happend befor e i changed the dizzy out with a complete unit from distributor king. Ill see if i have continuity on the pins from the map sensor before i spend the bucks on a new one.
JasonHi
17
Jun 18, 2020 06:34 PM
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
russ.shafer
May 19, 2013 02:29 PM
alfee
Aug 16, 2006 01:07 PM
