Does your car build boost in neautral?
Old Sep 11, 2003 | 03:11 PM
Obie
Guest
Posts: n/a
Default Does your car build boost in neautral?
My friends boost gauge dosent move in neautral is there something wrong with it or is it suppose to be like this?
Old Sep 11, 2003 | 03:15 PM
DubyaAye's Avatar
Default Re: Does your car build boost in neautral? (play)
mines dont move but the vacuum moves.
vtec.dc2's Avatar
you shouldn't build boost in neutral, but your gauge should still move as you change vacuum.
Old Sep 11, 2003 | 03:22 PM
99blusi's Avatar
Default Re: Does your car build boost in neautral? (vtec.dc2)
The only way you're going to get boost is if you take it to redline (not advised)
Old Sep 11, 2003 | 03:44 PM
speedworks's Avatar
Default Re: Does your car build boost in neautral? (99blusi)
or you can install a two step
Old Sep 11, 2003 | 04:14 PM
Bailhatch's Avatar
Default Re: Does your car build boost in neautral? (speedworks)
lots of cars can build boost in neutral. some can't. you do have to rev it pretty agressivly but not redline in any of the cars i have tried it on. (mostly just seeing if the bov was working after install)
i'm sure it's fine and is no indication of the quality or function of the setup.
i can make 3 psi but my car is really slow in neutral so i don't care
Old Sep 11, 2003 | 05:08 PM
red cx's Avatar
Default Re: Does your car build boost in neautral? (Bailhatch)
You can build boost in neautral with a two step. Two step is great to build some boost off the line at the track.
dan_w_82
Mar 28, 2006 11:37 AM
civicdx1
May 8, 2005 12:21 AM
2 point 0
Dec 31, 2004 03:09 PM
turbonitrousgsr
Oct 6, 2003 06:54 AM
Ray
Jul 7, 2001 07:34 PM
