Got fire, fuel pressure??
1994 EX
MY car sometime will not start
This only happens about once or twice a month.
It either starts or it does not start there is no turning it over untill it finally starts.
Fire = Good
Compression = Good
Fuel = I am unable to check the pressure with a gauge but it does have strong pressure at the check point. The fuel pump does come on when you turn the key.
How can do you check the "fuel pressure regulator" and will that keep the engine from running.
Got anymore ideas or anything else to check??
Fire = Good
Compression = Good
Re: Got fire, fuel pressure?? (ronqqq)
Hard wire a direct Re-Wire kit to fuel pump to battery, this is the best thing you can do to keep volts steady at the pump from the battery. Sounds lie you have some electric problems somewhare stealing voltage from your pump
Re: Got fire, fuel pressure?? (PK SPEED)
The fuel pump does come on and does pump the fuel . there is pressure at the check point of the fuel rail.
gabrielsousa
04-16-2014 05:17 AM
