Spark plugs and Ideal vaccume locations.
I cant get the search function to work right and I lost the slip I had the NGK spark plug #'s on so what is the plug number for 1 step colder and 2 step colder for a D16A6.
And for the vacume lines. I am using a 14B whats the vaccume nipple on the charge pipe flange for?factory wastegate?
I dont have a boost controler so do you think the 7 pound spring in a deltagate wg will actually be 7?
Modified by kid-honda at 10:31 PM 4/15/2004
Re: (kid-honda)
ok well as far as i know u want 1 step colder for the spark plug, and i dont know if its different but im running BKR7E's on my turbo gsr. also u should get the boost level yur spring is at, although im seeing 9 on a 5.8 psi spring, i think its cause i blocked off the top of the tial port tho for a boost controller.
