boost creep? what is it?
Old Apr 15, 2006 | 09:16 PM
the.hamburglar's Avatar
Default boost creep? what is it?
ok what is it exactly? i think im getting it. here we go. i have a 5psi spring in my wastegate and in 2nd gear it will stay at 5 and then 3rd gear it will slowly go to like 8 and then 4th gear it will go up to 12psi? is this boost creep. it slowly moves. its not all at once. i kinda of like it actually because i cant get traction anyways in 2nd and beginning of 3rd and then in 4th its full out hardcore. but really i know its bad what can i do to stop it?
Old Apr 15, 2006 | 09:50 PM
Dunc's Avatar
BCICAN
Default Re: boost creep? what is it? (the.hamburglar)
Yes that is boost creep....if you wastegate is set at 5psi and it slowly goes to 12. It's not exactly "bad" if you are tuned for it. It just means that you need a better manifold and/or a better wastegate.
To stop it, get a manifold with a more centrally placed wastegate hole on the manifold. By central I mean one that is not one just one or two runners. By a better wastegate I mean that the turbonetics deltagate one sucks and is known for doing this. Try a Tial or something like that.
Old Apr 15, 2006 | 09:56 PM
Default Re: boost creep? what is it? (Dunc)
ok cool. thanks. but what actually causes it because if it were "creeping" or leaking out wouldnt that cause my boost pressure to decrease?
Old Apr 15, 2006 | 10:03 PM
EK k kay's Avatar
Bad wastegate location and you are not letting enough exhaust out of the wastegate or you have a shitty wastegate.
Old Apr 16, 2006 | 12:21 PM
Default Re: boost creep? what is it? (EK k kay)
but how still. i need to understand what going on in there to cause it. i might be able to fix it
Old Apr 16, 2006 | 12:22 PM
would it be a bad wastegate spring?
Old Apr 16, 2006 | 01:26 PM
stockredej1's Avatar
Your wastegate cant pull enough exhaust out to stop your turbo from going over 5psi, its not a bad spring or anything. only way to fix it is like they said above, better wastegate or better manifold.
What wastegate and manifold are you using?
Old Apr 16, 2006 | 01:30 PM
Default Re: boost creep? what is it? (stockredej1)
ssauto. it worked fine a while back
Boosted00
Jan 19, 2018 01:51 PM
DelSolMarine
Nov 16, 2008 07:43 PM
2kTeg
Jun 12, 2005 10:34 PM
Ls1 FD3s
May 31, 2005 09:49 AM
Turbo_Si
Aug 19, 2002 07:44 PM
