cant boost over 4 psi
Old Mar 2, 2005 | 08:07 PM
  #26
dustin's Avatar
Default Re: (fro)
What wastegate? You shouldn't be using the top fitting without a boost controller on a tial etc...
You want the side port..
Old Mar 2, 2005 | 08:34 PM
  #27
fro's Avatar
fro
Default Re: (dustin)
yeah your right i dont know what i was thinking when i said that sorry but it is the side port and not the top.
Old Mar 3, 2005 | 09:44 AM
  #28
TA Performance's Avatar
i dont know but i still have the same problem... i checked all the couplers and pipes everythings hooked up
Old Mar 3, 2005 | 12:44 PM
  #29
Antilag's Avatar
Default Re: (fro)
Is the wastegate used, if so buy a new spring. what size turbo are you using?
Old Mar 4, 2005 | 06:27 AM
  #30
fro's Avatar
fro
Default Re: (9sech22civic)
im using a t3/t4 turbo and the wastegate is used. but what is the point of buying a new spring if its not the spring thats causing it to over boost
Old Mar 4, 2005 | 06:29 AM
  #31
fro's Avatar
fro
Default Re: (Boro_DC2)
is your welds holding up on the charge pipes check to see if there is no leaks in the welds.
Old Mar 4, 2005 | 09:46 AM
  #32
Default Re: (fro)
ok my tial 38mm is used but i bought a new 10lbs spring so the spring isnt the problem, my welds are great i dont see any leaks tho... im stuck
Old Mar 7, 2005 | 08:06 PM
  #33
fro's Avatar
fro
so i put in a different spring to see if it was the spring and it wasnt. i lubed up my wastegate to its unstuck and i still have the problem of over boosting.
Old Mar 7, 2005 | 09:45 PM
  #34
my problem was that the compressor wasnt giving good vacuum
Old Mar 10, 2005 | 06:39 AM
  #35
fro's Avatar
fro
anybody have any ideas of what it could be besides the wastegate stuck
Old Mar 11, 2005 | 06:26 AM
  #36
fro's Avatar
fro
Default Re: (fro)
bump
Old Mar 11, 2005 | 09:23 AM
  #37
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (fro)
if you have boost spikes.. not just always being over boosted... thats usually an indication of a poorly designed manifold.
Old Mar 11, 2005 | 12:52 PM
  #38
turbo-kits-com's Avatar
Do you have a boost gauge?
1) Hook the boost gauge up directly to the compressor and check the PSI levels right out of the compressor.
2) Hook the boost gauge up to the intake manifold so you can read the boost level at your throttle body... A .5 - 1 PSI drop is expected, anything over and you have a leak somewhere in the plumbing.
Jesse @ Turbo Kits.com
Old Mar 11, 2005 | 11:53 PM
  #39
fro's Avatar
fro
Default Re: (turbo-kits-com)
i think i found out what it is. my wastegate never used to spin and and now it does i think its over boosting from that
turbo-crx
Jan 24, 2009 09:06 AM
94turboeg
Aug 13, 2007 12:08 AM
turbo95eg6
Jun 12, 2005 12:15 PM
pip9
Sep 24, 2004 09:17 AM
Snafu-Si
Mar 5, 2002 02:07 AM
