can't adjust my FPR...
Meh. I can go down with my B&M.. Down to 20 with my walbro if I wanted. Then again. my B&M seems to defy all laws of physics when it coesm to B&M being shitty and having little control.... lol
You can turn down a b and M if you drill a small hole in the bottom of the regulator to relieve pressure...with a fuel pump you shouldnt be able to lower it greatly unless the regulator has been drilled...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">You can turn down a b and M if you drill a small hole in the bottom of the regulator to relieve pressure...with a fuel pump you shouldnt be able to lower it greatly unless the regulator has been drilled...</TD></TR></TABLE>
Yeah that's generally the truth. I've only heard of a few stories where ppl can still bring the pressures down quite a bit. mines included without drilling
But that's most likely your problem. you got a walbro pump. too much rpessure for that stock regulator return.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Yeah that's generally the truth. I've only heard of a few stories where ppl can still bring the pressures down quite a bit. mines included without drilling
But that's most likely your problem. you got a walbro pump. too much rpessure for that stock regulator return.</TD></TR></TABLE>
what can i do then? i'm running super rich right now. it doesn't run right. i feel it bog a lot.
will tuning help? i'm getting tuned tomorrow!!
i just want to get all the troubles out so the tuner and tune it quick and free of troubles.
http://www.theoldone.com/articles/regulator
Here's the link. Hope it helps you. I've done it a few times, worked perfectly.
