255lph fuel pump problems
Old Mar 8, 2004 | 12:51 PM
gsrvtechatch93's Avatar
Default 255lph fuel pump problems
i got a fuel pressure reg and b&m fuel gauge not the best setup. but anyway when i use just the fuel pressure reg i put it to 41psi but as soon as i hook up the fuel pump it jumps super high how do i hook the fuel pump up so it stays at my desired psi? and i cant bring down the pressure low enough with the reg
Old Mar 9, 2004 | 03:06 AM
B17AGSR's Avatar
Default Re: 255lph fuel pump problems (gsrvtechatch93)
I would slap the stock fpr back on for now. What kind of fpr do you have?
Old Mar 9, 2004 | 06:40 AM
vtecb20coupe's Avatar
B A N N E D
you said that you use the fpr and set it at 41 psi, so i'd assume it's a b&m fpr, since you have the gauge as well. it is known with the walbro 255 pumps to increase your fuel pressure reading. this is why it is necessary to lower your fuel pressure with your b&m fpr. that is what it is there for.
there are a few threads on the boards that have covered this in the past.
Old Mar 12, 2004 | 04:33 AM
im sorry i didnt make my self more clear i have the b&m fpr turned all the way down and its still way over my desired setting
solattack77
Mar 30, 2011 11:38 AM
scuffywin
Jun 5, 2007 04:15 PM
Boognish
Jul 24, 2005 08:16 PM
n1_ek
May 19, 2004 11:56 PM
MrDX
Dec 20, 2001 01:39 PM
