*Tony1 distributorless sensor*
i think i see a picture of it somewhere here. didn't bring my camera to nopi, so i wasn't able to get any pics of your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">did I miss a previous post? whats this?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1170475
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 »</TD></TR><TR><TD CLASS="quote">At least it's too complicated to immediately be the next bandwagon.
Werd..
Nice work Palo
</TD></TR></TABLE>Werd..
Nice work Palo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">so basically what's the point of getting rid of the distributor and running this setup?</TD></TR></TABLE>
individual cyl timing
less moving parts to fail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 »</TD></TR><TR><TD CLASS="quote">At least it's too complicated to immediately be the next bandwagon. </TD></TR></TABLE>
not complicated at all. its really a very simple setup
Tony
Tony
these coil pack i'm running are way stronger than COP. they are the same coil packs and ignition system from Kenny Tran's 8 sec civic. you can run full boost 30+ psi on them and still run the gap .030 you will never have a misfire or ignition issue with this setup. if it can light a methanol mixture without a problem, gas is a piece of cake. they are a sequential spark system (4 ign outputs).
the coils are made by mercury marine and require a strong ignition system like an m&w, autronic 500R or motec cdi-8.
they aren't for individual cylinder timing. that is controlled by the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">
not complicated at all. its really a very simple setup </TD></TR></TABLE>
Don't tell em that, by the time I get mine done, everyone will have em
