Can my block be saved? Pics inside
Old Dec 4, 2003 | 05:07 PM
TOFU.man's Avatar
Default Can my block be saved? Pics inside
I have recently aquired this B16A2 engine block. The guy I got it from blew out the #4 piston (spraying a 75 shot). As you can see the top of it is chipped and the sleeve is royaly fucked up. As for the pics of the back of the block i was wondering what all these little lines are... they look like cracks but i can catch the ridge with my fingernail...I was wondering if this was normal also.
Can this thing be saved and if so does it just need to be resleeved, pistons and rods?
Old Dec 4, 2003 | 05:16 PM
spoolinlude's Avatar
I live under a rock
Default Re: Can my block be saved? Pics inside (B16AHondaSi)
That sleeve needs replaced..... or bored out like whoa....... and those cracks in the block...... well, you can fix anything, i've seen holes punched in blocks repaired and reused, never a honda thou........ i guess anything is possible, i for one thou wouldn't mess with that
Old Dec 4, 2003 | 05:24 PM
booscivic's Avatar
I would get another block!!!
Old Dec 4, 2003 | 05:41 PM
rtype11's Avatar
definately needs to be cleaned up before you do anything, those spider cracks are most likely just dirty casting flaws, you can clean em up with grinding if you want, if i see that cylinder right it is delaminated and maybe cracked for sure new sleeves. pistons depend on their condition, were they also damaged when #4 went???? rods same ????.
hard to tell as your pics take up more than a page each.
tegasaurus's Avatar
Default Re: (booscivic)
If those cracks don't leak then the blcok is fine. Just re-sleeve it or bore the bajesus out of it.
Also if you want to be safe, throw a lil JB weld on the deper cracks.
-Ryan
Old Dec 4, 2003 | 05:55 PM
alpha's Avatar
I don't see any cracks that look like they are going to be a problem. Have the block bead blaster or acid dipped (preferably bead blasted) and paint the block with high temp paint. It will be as good as new after that and resleeving.
Old Dec 4, 2003 | 07:06 PM
TOFU.man's Avatar
Default Re: (0x64)
I am going to clean this thing up tonight i would like for it to be saved and from what it sounds like most of you think it can.
Any other people want to throw in on this people that have dealt with this and blocks as hidious as this feel free to jump in and give your .02 on things.
Old Dec 4, 2003 | 07:10 PM
racerxadam's Avatar
Default Re: (B16AHondaSi)
the pics of the outside of the block don't look like cracks to me. they look like flash from the mold that the block was cast in. I have been fooled into thinking that they were cracks as well on my own blocks when oil and dirt get in there.
Old Dec 4, 2003 | 07:13 PM
alpha's Avatar
You want to see a messed up block? I will post pictures of my block this weekend. After acid dipping, resleeving, jet washing and painting it with hi temp paint it looks damn good now. Looked exactly like your block does.
Old Dec 4, 2003 | 07:17 PM
kid-honda's Avatar
I have not seen one honda motor without them tiny lines.
Old Dec 4, 2003 | 09:05 PM
TOFU.man's Avatar
Default Re: (kid-honda)
bump? anybody else
Old Dec 4, 2003 | 09:14 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16AHondaSi &raquo;</TD></TR><TR><TD CLASS="quote">bump? anybody else</TD></TR></TABLE>
If u don't care about the cosmetic appearnce of your block, clean it and sleeve it put it in and ride!
I am bead blasting, sanding, and painting mine over the winter
Old Dec 4, 2003 | 09:47 PM
Kataku2K3's Avatar
Default Re: (99blackcivicSi)
I agree with everyone else... You see those "cracks" on every Honda block, some have more than others but they are in fact just traces in the casting... If for some reason I'm missing something and they are cracked I'm sure you could TIGed... I can't tell how deep the scoring is but I definately wouldn't go more than 1 millimeter over on stock sleeves (0.50mm for me MAX, but I hate stock sleeves)... Though it would cost a bit, I would just resleeve the block (if you still want a B16A bottom end)... Just my $0.02... If it's cracked and the sleeves are beyond overboring get a B18C and resleeve, hehe
Old Dec 4, 2003 | 09:51 PM
PrecisionH23a's Avatar
Default Re: (Kataku2K3)
The cracks on the block do look like they were due to casting, you will find out once you strip the block down and inspect the inside of it. Let us know if you need any more help.
Old Dec 4, 2003 | 10:16 PM
TOFU.man's Avatar
Default Re: (GudeH23a)
I will be puttin it on a stand tomorrow and pulling it apart.I have cleaned it up the best I could with some good ol simple green. I have acess to a beadblaster my friend has one at his house (I have no idea why he never uses the thing).
Well with a resleeve, new pistons, and rods I will bring this B16A back to life.
I will keep you guys posted on progress.
Wish me luck on my new project.
Old Dec 4, 2003 | 11:21 PM
TOFU.man's Avatar
bump
Old Dec 5, 2003 | 12:25 AM
TURBO4drTypeR's Avatar
Go get it resleeved and get yourself aftermarket pistons and rods!!!
No_Limits_Accord
Jan 9, 2010 09:39 AM
D0GMAN
Apr 12, 2005 08:01 PM
fullracegsr
Apr 6, 2004 05:37 PM
otakueric
28
Feb 27, 2004 01:02 PM
g2turbo
Sep 12, 2003 12:30 PM
