Downpipe hitting oil pan
Old May 11, 2003 | 10:04 PM
SiRkid's Avatar
Default Downpipe hitting oil pan
Well I decided to hook up my custom dp to the stock cat to quiet it up as I need to go to work tomorrow .
I struggled but got it bolted up and well...one of the welds is right under the pan and it hits the oil pan during certain times when i accel.
I knew it would be a tight fit(From test fitting) but I thought I would be ok from hitting......
will I be ok like this????????????
I will eventually get it fixed but I totally am not in the mood to do so right at this moment
*fyi , I have no flex pipe on my dp*
i feel it might be under too much stress and will eventually crack.
any thoughts?
Old May 11, 2003 | 10:15 PM
turbod16y8's Avatar
Default Re: Downpipe hitting oil pan (SiRkid)
i have no flex pipe and my dp hit th eoil pan a lil bit... been boosting for over 3 months no problem..
Old May 11, 2003 | 10:16 PM
Flamenco-T's Avatar
for temporary, you'll be fine
Old May 11, 2003 | 10:22 PM
SiRkid's Avatar
Default Re: Downpipe hitting oil pan (Flamenco-T)
temporary as in how long???? i know thats a dumb question....
so far id say 3 months and ill be ok
im actually more worried about the temp of the dp touching the pan than the tapping.
my old stock pan took a shot from a little boulder(about 6 inches in diameter) and it dented the **** out of it(hit it at like 40 mph) and it held up just fine
Fully_Built
Feb 6, 2008 09:21 AM
EX-T
Jul 17, 2007 07:35 AM
EJ1 wilcox
11
Feb 16, 2005 08:57 AM
gdrum
Jan 27, 2004 05:58 AM
civictypenos
Mar 9, 2003 07:05 AM
