What to use for an intake coupling - SC61 and other turbos with 3.5" opening
What are you guys using? I've sourced some 3.5" piping, but what are you guys using for a coupling to the turbo and filter? What are you guys using for a filter?
Just curious, the biggest silicone couplers I can find are 3", and they're averaging $25/each which is outrageous. Anyone know if Napa has 3.5" radiator hose?
EDIT: Also, how much is it going to effect performance if I run a filter witha 3" opening?
Re: What to use for an intake coupling - SC61 and other turbos with 3.5" opening (MadCow)
take some pics id like to see how u make this
Re: What to use for an intake coupling - SC61 and other turbos with 3.5" opening (FredoSP)
hahaha, I'd love to see how I'm gonna make it too... just can't justify running mesh screen on an SC61.
I'll take pics once this thing takes shape... I don't even have the turbo yet.
New User
this will be wuite interesting actually. I myself am mindboggled in how he is going to make this work. I am hopefully bringing the turbo home to you this wknd as we discussed on the phone. if not this weekened we will figure out how to get it to you asap!
Re: (boosted jetta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted jetta »</TD></TR><TR><TD CLASS="quote">i've never seen a turbo with a 3.5" inlet??</TD></TR></TABLE>
Here's 4" inlet.
As far as what to use... this is a bad picture, but I recall Todd used part of a (domestic??) CAI to mount the filter off to the side a little. I think it was a piece off his old 5.0 before he turbo'd it. Here:
Here's 4" inlet.
Smarter than you
SC61 has a 3" inlet(E housing) unless you get a S housing then it will be 4".
Guest
Posts: n/a
Re: What to use for an intake coupling - SC61 and other turbos with 3.5" opening (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">SC61 has a 3" inlet(E housing) unless you get a S housing then it will be 4".</TD></TR></TABLE>
I was gonna say....I have something im working on for mine, im done with the screen bs
Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">I can get 4" Hose </TD></TR></TABLE>
You like some short women!
There is a K&N style for ford (I think its ford) that is 4 inch.. Im sure it would have enough surface area to supply air without a restriction.
crucian
01-02-2007 06:05 AM
lucas569
08-07-2002 09:14 AM
