Turbo Filter Question???
Old Jan 11, 2005 | 05:07 PM
Jradrebel's Avatar
Default Turbo Filter Question???
do they mass produce turbo filters for a 2000 Civic SI ??.. this is what is covering my turbo right now.. do they mass produce them for my car, or do i have to get it custom.. another question is it even needed??? or is what i have fine??
thanks!
Old Jan 11, 2005 | 05:34 PM
Jradrebel's Avatar
Default Re: Turbo Filter Question??? (JRadRebel)
anyone??.. i'm talking about a piping with the filter.. that goes under or over the radiator
Old Jan 11, 2005 | 05:38 PM
Dunc's Avatar
BCICAN
Whoa, custom make the piping if need be......but get a filter on that thing ASAP. You'll wish you had if that turbine gets intimate with a rock or something. Plus dirt is quite bad.
Old Jan 11, 2005 | 05:39 PM
Hockey27925's Avatar
yes they do make one, drag makes one u can call up urbanimport.com i think thats where i got mine for about 125
Old Jan 11, 2005 | 05:43 PM
evosol's Avatar
Default Re: Turbo Filter Question??? (Hockey27925)
I'm a fan of DIY, so... naturally i would suggest you just order a mandrel "u" bend and cut it, weld it up or take it to a muff shop and have them weld it depending how you want the bend. i'm sure its well under $125.
Old Jan 11, 2005 | 05:46 PM
-iLLuZioN-B18C1's Avatar
Default Re: Turbo Filter Question??? (evosol)
yeah, get a filter for that thing and try to fab up your own arm.
the fit in my engine bay was very very tight. so i had to get
some rubber hosing which never melted surprisingly from home
depot and threw on the filter on the other side
Old Jan 11, 2005 | 05:49 PM
Jradrebel's Avatar
Default Re: Turbo Filter Question??? (-iLLuZioN-B18C1)
yeah i was thinking of getting a rubber housing with a filter on it.. but i was scared it would melt.. i think i'll do that till i get the piping for it thanks
VtecBlissS2k's Avatar
bump.. cause my NA stock S2K can whoop his ***...haha,
jk'in radford, shoulda asked me first.. ida told you to just get a piece of mandrel bent pipe
kteller.com might have something, just guessing
Old Jan 11, 2005 | 05:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRadRebel &raquo;</TD></TR><TR><TD CLASS="quote">yeah i was thinking of getting a rubber housing with a filter on it.. but i was scared it would melt.. i think i'll do that till i get the piping for it thanks</TD></TR></TABLE>
yeah, mandrel bend will be much better. but unitl then rubber hosing will work
heres mine
might be a little hard to see but you get the picture
Modified by -iLLuZioN-B18C1 at 10:04 PM 1/11/2005
Old Jan 11, 2005 | 06:33 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRadRebel &raquo;</TD></TR><TR><TD CLASS="quote">do they mass produce turbo filters for a 2000 Civic SI ??.. this is what is covering my turbo right now.. do they mass produce them for my car, or do i have to get it custom.. another question is it even needed??? or is what i have fine??</TD></TR></TABLE>
It seems like common sense to me that you would just have to measure the inlet size for the turbo and order a filter with the same size flange....
Old Jan 11, 2005 | 07:16 PM
EJ1 wilcox's Avatar
Default Re: Turbo Filter Question??? (Hawkze_2.3)
I would definately get a filter on there ASAP... you don't know how much dust and junk you are sucking through the tight clearances in your turbo and into your intake manifold...
I used a UNI motorcycle filter on my car, which I bought from a parts store... it's small enough to fit in the small space I have to work with and filters the air really well... my turbo response actually improved when I switched from a screen like you are running to this filter...
Old Jan 11, 2005 | 09:07 PM
Default Re: Turbo Filter Question??? (EJ1 wilcox)
here is a better pic of my filter setup
Old Jan 11, 2005 | 09:20 PM
PrettyLude's Avatar
pm ben at importparts.com, he can sell you the pipe your looking for
Old Jan 12, 2005 | 11:11 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (PrettyLude)
seems like the 90 with the filter at the top works well. this is how i have mine.
Old Jan 12, 2005 | 11:29 AM
splitime's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I would definately get a filter on there ASAP... you don't know how much dust and junk you are sucking through the tight clearances in your turbo and into your intake manifold...
This is the route I went. Used a K&N rc-2330 filter. 2in inlet, 3in filter tapers - 2in. Little sucker, but it fits in there and I'm not screened anymore.
Old Jan 12, 2005 | 11:34 AM
vtec.dc2's Avatar
go to k&n website, they have tons of filter sizes, check your engine bay, picture the best location for filter and order from there.
Old Jan 12, 2005 | 12:21 PM
Jradrebel's Avatar
Default Re: Turbo Filter Question??? (vtec.dc2)
yeah imma do a rubber housing .. till i get the mandrel piping done.. thanks everyone
Old Jan 12, 2005 | 02:43 PM
DefiantGSR's Avatar
"the material we use is an orange flexible hose with a steel liner. If you
knowhere you want your filter to go, just figure out the length and we
will get a piece of material cut to length for you. I think it is
22$/foot fyi. If you have any other questions feel free to email me
back. Thanks!"-geoff
Old Jan 12, 2005 | 05:28 PM
Ben Huynh's Avatar
Here you go:
http://www.importparts.com/sho...=2217
It's also on sale!
RNPoo7
Nov 27, 2005 12:47 PM
Mag00n
Mar 30, 2004 07:18 AM
T3T495GSR
Oct 14, 2003 11:31 AM
myflysi
Jul 22, 2003 08:41 AM
ijjz
Sep 22, 2002 09:49 PM
