Built block completely acting strange need help diagnosing?
Old Jul 2, 2005 | 12:27 PM
NotPhilTran's Avatar
Default Built block completely acting strange need help diagnosing?
1991 honda crx si
b16a
j1 tranny
pr3 ecu
hondata wiring
sport compact sci
450cc injectors
walbro255
t3/t4e 63.48ar
tial wastegate
fmic
9:1 compression pistons .020 overbore
scat rods
acl bearings
honda headgasket
arp main and head studs
stock dizzy
old as **** spark plugs
msd 8.5mm spark plug wires
ctr crank pulley
10k timing belt.
stock fuel rail.
engine and head were checked good. leakdown and compression was perfect.
heres the problem, i start to build boost around 4k hit full boost at 5k nothing over 11.5 psi.
around 5200 rpm i am making about 140 whp and then my power drops to 52whp and i dont know why. one run i made 180whp because i didnt drop power. i dont know whats going on.
i was told it was either the valvetrain or the ignition or timing.
what is the stock b16 timing supposed to be set at? its a little under the red timing mark.
stuck at hte dyno lost for words.
Old Jul 2, 2005 | 01:15 PM
Muckman's Avatar
Moderator in Chief
Default Re: Built block completely acting strange need help diagnosing? (NotPhilTran)
How is it being tuned?
Old Jul 2, 2005 | 04:24 PM
lodo1's Avatar
Default Re: Built block completely acting strange need help diagnosing? (Muckman)
hondata is the management
Old Jul 3, 2005 | 09:33 AM
Zakar's Avatar
who tuned it?
Old Jul 3, 2005 | 10:04 AM
ExospeedAMcrx's Avatar
do you have an exhaust system? catalytic converter?
Old Jul 3, 2005 | 11:11 AM
lodo1's Avatar
Default Re: Built block completely acting strange need help diagnosing? (exospeedAMcrx)
its a full 3 inch exhaust from the downpipe back, no cat. the dyno owner is tuning the hondata.
the problem is the graph is all choppy, no smooth curves whatsoever, max power at about 4200, and dropping
Old Jul 3, 2005 | 03:15 PM
earl's Avatar
Default Re: Built block completely acting strange need help diagnosing? (tdocrx)
vtec not working because of low oil pressure?
Old Jul 3, 2005 | 05:03 PM
Default Re: Built block completely acting strange need help diagnosing? (earl)
it sounds like its engaging.
my oil lines are 4an, but i have a reducer on it.
Old Jul 3, 2005 | 05:44 PM
earl's Avatar
many run unreduced -6an
Old Jul 3, 2005 | 07:03 PM
lodo1's Avatar
-6an for the turbo feed line?
Old Jul 3, 2005 | 08:38 PM
earl's Avatar
no, sorry, I thought you were an ls/vtec. I see you have a B16
not sure why you mentioned your turbo feed line size
Old Jul 3, 2005 | 09:36 PM
lodo1's Avatar
ohh, not my car, just workin on his. he as a b16, bored .5mm over, 9.1:1 comp, b16a obd0 head. sounds like his lma's are bad, but can that really cause that much of a power loss?
Old Jul 4, 2005 | 06:37 AM
yeah, were gonna try a new dizzy and spark plug wires here tommrow.
ef9civicgen4
Aug 23, 2007 05:16 AM
JDMlyfestyle
Jun 15, 2006 07:55 AM
ryanplayjoint
16
May 29, 2006 02:32 PM
NotPhilTran
Jul 21, 2005 06:36 AM
