budget boost build
Old Jan 31, 2012 | 11:05 PM
budgetbuild's Avatar
Default budget boost build
I have a 89 crx and it is setup for 12lbs, but i blew a head gasket so while have it out and apart I figured on building it up a little bit, but not going to crazy. I already know im gonna put arp headstuds and was thinking working on the lower end. if anyone has ideas/tips/links to good parts i would appreciate it greatly
Old Jan 31, 2012 | 11:23 PM
donut69326's Avatar
Default Re: budget boost build
Eagle rods, weisco pistons, acl race bearings, get a good machine shop to check you're block and crank.
Old Jan 31, 2012 | 11:25 PM
thanks ill look into those
Old Jan 31, 2012 | 11:38 PM
.Manny.'s Avatar
Touching My Member
tuning above all else
Old Feb 1, 2012 | 12:34 AM
B18b1EfHatch's Avatar
make sure u get a thicker head gasket so u dnt blow it again.
Old Feb 1, 2012 | 08:46 AM
yes manny the exterior is almost completely stock while all of my money is going under the hood
thanks b18b1 will do
Old Feb 1, 2012 | 10:24 AM
.Manny.'s Avatar
Touching My Member
Don't forget brakes and suspension too. Remember, all the power in the world doesn't matter if you can't put it down to the ground.
What is your power goal? Never go by PSI, 12 psi will yield different results across the board depending on what turbo you're using.
Old Feb 1, 2012 | 08:10 PM
im putting the 4 wheel disc setup off of a 90 si on and i already have suspension work done
Old Feb 8, 2012 | 10:05 AM
im thinking about putting a traction bar set up on my car and was wondering if there was anyone who has had experience with any brand
Old Feb 8, 2012 | 10:41 AM
wreckin-rex91's Avatar
Innovative, Full Race, Explicit Speed Performance, ETD... just search, all of these brands are good. I like Explicit Speed, but I have a Innovative and if I buy another one I would probably use Explicit Speed.
Old Feb 8, 2012 | 11:29 AM
jdmef69's Avatar
I have avid traction bar. Looks nice and fit perfect. Only down side is it took 2 months to receive it. And send the wrong hardwear. They claimed it got stuck at the Canadian boarder.
bowtieboy911
12
Apr 4, 2011 03:36 AM
dc2ls-vtec
Aug 7, 2008 01:06 PM
fastboy559
Apr 19, 2008 08:43 AM
fast92hatch
May 12, 2007 08:26 AM
HYBRID_H@TCH
Apr 24, 2004 04:48 AM
