BOV before IC?
Old Jun 13, 2002 | 11:10 PM
  #26
2000_Civic_Si's Avatar
Default Re: BOV before IC? (B20C5 Turbo)
On 91-96 MR2 Turbo's the BOV is before the intercooler. Just wanted to share.
Old Jun 14, 2002 | 01:23 AM
  #27
R-1303's Avatar
Default Re: BOV before IC? (inspyral)
Some of the Supra guys put their BOV's on their i/c piping...
My friend puts his bov almost at the same spot on his supra...the point is that the charge that is going through the intercooler causes pressure drop..its phsyics..that is why bigger and thicker intercoolers causes more pressure drop allowing more boost do to that pressure drop in the manifold..also as the charge goes through the intercooler its looses pressure so the closer you mount the bov next to the intercooler the more loud its gonna be...becuase of the less pressure drop. thats why the supra guys put theirs at that location.
Old Jun 14, 2002 | 01:27 AM
  #28
R-1303's Avatar
Default Re: BOV before IC? (2000_Civic_Si)
True..my cousin has a mr2..i think its because the pipping design on the car..but i will look more into that one..and thats why his car blows off so daam loud!
Old Jun 14, 2002 | 02:54 AM
  #29
clean's Avatar
New User
Default Re: BOV before IC? (R-1303)
i know on silvia's and 240's w/ sr20det's they put the bov right after the compressor. i am getting my sr20 soon and wanted to know why they did this too. i didnt get an answer but none of them are routed back to the intake and i imagine when having a MAF it would be important for the engine to see that air cause it was already acounted for. i'm sure you wouldnt want to vent the air from the turbo to the intake being 300 degrees or so. this is a good ? and is an interesting thread to read all the responces. but if anyone has looked @ thier directions for the type s it has a diagram putting the bov between the intercooler and tb, so....... ?
Old Jun 14, 2002 | 04:25 AM
  #30
BlueShadow's Avatar
... Why? Because the air temperature before the intercooler can exceed 300 degrees F, and all of this heat is removed from the intake charge air by the intercooler. If we choose to vent the excessive airflow BEFORE the intercooler, it is simply hot air released to the atmosphere. If we choose to vent the excessive airflow AFTER the intercooler, we have effectively heatsoaked our intercooler and wasted xx% of cooling efficiency for no good reason at all. That's not a good practice in racing...
thats a very good reason indeed! i never thoiught of it like that. however, what about the issue of the air getting turbulent between the pre-IC BOV and TB. will it be better, worse or the same as if the BOV was place right before the TB?
cstay
Jan 19, 2022 03:39 PM
Silvertc
Dec 31, 2009 12:41 PM
Mr HYDE
Aug 30, 2006 05:09 PM
1FastCoupe
Aug 18, 2005 07:59 PM
SLIMJIMsi97
Jun 18, 2003 04:40 AM
