My bov leak
Old Jun 16, 2003 | 02:41 PM
SLIMJIMsi97's Avatar
Default My bov leak
I lost 2 psi at high rpm (between 5500 and 7000) I think it's my bov (1 g dsm bow) it's a old bov and I think the spring is maybe tired.....anyone ?
Old Jun 16, 2003 | 02:46 PM
TeStUdO's Avatar
it could be your intercooler piping. have you made sure all your couplers are really tightened down? can you hear any air escaping anywhere?
Old Jun 16, 2003 | 05:01 PM
ion_four's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">it could be your intercooler piping. have you made sure all your couplers are really tightened down? can you hear any air escaping anywhere?</TD></TR></TABLE>
This seems like the more likely culprit.
BTW, how much boost are you running, Slim? If it's less than 15psi, I'd wager it's not the BOV.
Old Jun 17, 2003 | 04:50 AM
All the couplers are ok and my i/c too. My bov suck air at idle and always make noise it's why im thinking the bov is the problem. I boost 8.5 psi.
Old Jun 17, 2003 | 06:48 PM
A blow off valve can't leak ? ....can the wastegate be the problem?
Old Jun 17, 2003 | 06:53 PM
TeStUdO's Avatar
your BOV sucks air at idle??? do you have a vacuum source hooked up to it???????
Old Jun 17, 2003 | 07:32 PM
yes....from the intake
If I block the piping after the bov with my hand the motor don't shut down and the bov make noise (suck air) and if I block the piping and the bow with my other hand the motor shut down.
Old Jun 17, 2003 | 10:21 PM
ion_four's Avatar
A lot, if not all BOV's suck air at idle. There is more vac. in the manifold than in the intake pipe, thus it is open.
Old Jun 18, 2003 | 04:40 AM
Thank's for the info.
I boost 8.5 psi (the max of the wastegate) under 5500 rpm..after that my guage drop at 6.5 ....it's weird!!!
jsbayer
Jul 27, 2009 06:29 PM
welfarepc
Aug 19, 2007 08:26 PM
4_door_teg
Jun 17, 2006 09:46 PM
1FastCoupe
Aug 18, 2005 07:59 PM
Islander9407
Jul 1, 2001 10:18 AM
