How to Calculate engines air flow rate?
Hey, again...
I was reading blueshadows archived post about reading compressor maps, and in section 2, he explains that you need to calculate your engines air flow rate and convert it from CFM to lbs/min.
After finsihing the article, I did several searches on calculating air flow rate, air flow rate, etc, and came up with nothing.
So, how do you calculate your engines air flow rate? I wanna be able to read these damn maps! lol
Re: How to Calculate engines air flow rate? (CustomCockpits)
Most of the questions you have been asking lately are covered in Maximum Boost by Corky Bell. Its one of the best investments you can make. Its the turbo bible.
ps. buy one for each washroom
ok.. i get this part:
(RPM*(displacement in liters*61.023744)/3456 = CFM theoretical
(1 ltr = 61.023744 Cubic Inches)
BUT, u need air flow under boost, so...
(WHAT THE HELL DO I DO HERE??????)
THEN convert that number (which is CFM) to Lbs/min, so i do one of these:
@ 48 degrees F : (CFM * 0.078125) = LB/MIN
@112 degrees F : (CFM * 0.070318) = LB/MIN
@175 degrees F : (CFM * 0.06251) = LB/MIN
SOMEONE HELP ME FIGIURE OUT YHE MIDDLE PART!
Re: How to Calculate engines air flow rate? (int3gra)
New User
Quick and dirty engine flow rate in pounds / min:
= RPM * Displacement (L) / 12964 * (boost psi + 14.6)
example 8000 RPM, 1.8L, 8psi = 25.1 lbs/min
The 12964 is just a fun little number incorporating liters/min to lbm/min conversion and the bottom half of the pressure ratio. This formula ASSUMES your intercooling system can bring the temperature back down near ambient temp.
Re: How to Calculate engines air flow rate? (dbman96)
I would like to be able to read these maps before the books arrives.
[Modified by CustomCockpits, 6:55 AM 6/14/2002]
Hi Custom...
check out this jpeg I made a while back, I learned how to figure out engine CFM from MB, so this is how I do it.
if the pic doesn't show click the link http://www.eframes.com/ef-cgi/c/csma...compressor.JPG
I would also check around further on how to change CFM to LB/MIN, you need to find the conversion factor to find out how much one cubic feet of air weighs at XXX degrees. The conversion factors I got came from a very reliable source, but it is my ONLY source and I prefer atleast two different sources.
something I should add, the VE or Volumetric Efficiency will be different from engine to engine (obviously) its up to you to figure out what the VE is for your specific engine. I have done wute a bit of research on H22 VE's and have found the the H22 has a peak VE of 102% at 7000 RPM's (1.02 in the formula), and the S2000 has a peak VE of 112% at peak HP RPM.
So I suspect that teh VTEC B18C1/5 and B16 are somewhere between 102-112% VE. Not so sure about the non-VTEC's though, those are prolly around 80-90%.
Re: How to Calculate engines air flow rate? (BlueShadow)
where would one begin to search to find out the VE??? i dont even know where to begin
Does this mean anything? can i somehow get the VE outta these numbers? (B16A3)
(EDIT: removed image cause its pointless)
[Modified by CustomCockpits, 1:52 PM 6/14/2002]
[Modified by CustomCockpits, 2:24 PM 6/14/2002]
i just started searching http://www.yahoo.com for "prelude volumetric efficiency" and some different variations (H22, VTEC, etc), but I think I got lucky. There was a website that had an article on the S2000, that happened to mention teh S2K's VE, they also mentioned the H22's Ve for comparison.
if anyone knows this, or can find where to find it (did that make sense?) I will pay them!!!!!!!
air, airflow, boost, calculate, conversion, efficiency, figuring, flow, formula, h22, honda, lbmmin, rate, s2000, volumetric
