Bore VS spool time
Old Jul 23, 2003 | 10:50 AM
  #26
15psi of fun's Avatar
Default Re: Bore VS spool time (Boostfed)
So it’s the problem of not having the safety of reboreing if something happens. That is why every body thinks you should stay at 81mm but if you have darton sleeves can’t you replace one if it gets too damaged and you would have to go over 85mm.
Old Jul 23, 2003 | 12:03 PM
  #27
93LSivic's Avatar
Default Re: Bore VS spool time (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">So it’s the problem of not having the safety of reboreing if something happens. That is why every body thinks you should stay at 81mm but if you have darton sleeves can’t you replace one if it gets too damaged and you would have to go over 85mm.</TD></TR></TABLE>
This is true. You can replace one Darton sleeve if needed. Thats a good reason to use them instead of GE. Pay more for Dartons, but you get what you pay for.
Old Jul 23, 2003 | 12:04 PM
  #28
Boostfed's Avatar
New User
Default Re: Bore VS spool time (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
This is true. You can replace one Darton sleeve if needed. Thats a good reason to use them instead of GE. Pay more for Dartons, but you get what you pay for. </TD></TR></TABLE>
There are more reasons than that but I won't go into that again. See sig.
Old Jul 23, 2003 | 03:17 PM
  #29
intekragsr's Avatar
thanks for all the good info.
hoffmanb16
Aug 31, 2009 11:27 AM
fled
Mar 4, 2005 03:46 PM
91DroppedHatch
Nov 10, 2004 09:00 AM
*Boostwerks*
Sep 20, 2002 12:12 AM
