boosting an h22 with stock internals
Old May 17, 2006 | 08:11 AM
hondah22acivic's Avatar
Default boosting an h22 with stock internals
hey all...
i'm starting to tune my 93 jdm h22a that ive put a t3 on. i was wondering how much boost it'll handle.
my setup, tubular manifold, 35 mm external wastegate, t3 turbo, 30" by 12" by 3" front mount intercooler, dsm b.o.v., bbk 70mm t.b., full msd ignition, dsm blue top injectors, aem rail f.p.r. and filter, and a walbrough 255lph pump.
i've just got a 4 psi spring in the wastegate right now, i'm gonna tune it on that, and turn it up gradually on the dyno.
Old May 17, 2006 | 08:29 AM
purpleh22's Avatar
Default Re: boosting an h22 with stock internals (hondah22acivic)
Injector size will limit the amount of boost that you can use. Should be able to run 8lbs or so if tuned right. Are you running Chrome, Hondata, Uberdata, Neptune or something to allow you to alter timing and fuel mixture? 300 whp +++ can easily be run with the proper setup and tuning.
Old May 17, 2006 | 08:34 AM
Default Re: boosting an h22 with stock internals (purpleh22)
well i have the p13 pcm. i heard from somwhere you can only use that stuff on the p28.
i was going to keep it conservative for now, and run low boost and just tune it with the vafc2
Old May 17, 2006 | 10:23 AM
toyH22's Avatar
Id say build before you go turbo, the ringlands are the weakpoint. Get it tuned right the first time!!!!!! Trust me I know from experience.... I to said I was going to keep it conservative, but I couldn't hold back from wanting more power... I took the cheap route to get it tuned and my motor went!!!!
Old May 17, 2006 | 09:26 PM
i'm looking into uberdata, and the things i'd need to be able to do it myself. doing a lot of research. i think i'm going to buy an eprom burner for like 80 bucks, and all the other stuff. idk. i have the time and knowledge, so i'll give it a shot.
Old May 18, 2006 | 03:33 AM
N20civicB18's Avatar
$300 For a Street tune if you Have a chipped ECU, if not we sell chipped p28's for $175
E-mail me Kyle@Oceanstatetuning.com
julianbc2
Jun 23, 2010 12:40 PM
JasonST
Mar 18, 2008 11:46 AM
btrim23
May 4, 2006 09:09 PM
gen4h22a
Aug 12, 2004 01:12 PM
angela_itr
Jul 9, 2004 12:58 PM
