what kind of fuel setup?
Old Jun 22, 2010 | 05:08 PM
julianbc2's Avatar
Default what kind of fuel setup?
i have a integra stock ls with 101,*** miles on it. motors healthy. im going to run a t3 garret air research turbo, blox log manifold, tial 38mm .9 bar waste gate (13psi), 2.5in intercooler piping, hks bov, xs power intake manifold, turbo xs boost controller, 3 inch down pipe, and open dump tube. im only putting 8psi-10psi. its a daily driver. whats should my fuel setup be? what size injectors? do i need a fuel rail?
Old Jun 22, 2010 | 05:17 PM
Cimburke23's Avatar
Default Re: what kind of fuel setup?
LOL @ running 8-10psi with a 13psi wastegate.
Old Jun 22, 2010 | 05:26 PM
julianbc2's Avatar
thats just in case i might up the boost.
Old Jun 22, 2010 | 05:34 PM
Poootie's Avatar
he EL OH EL coz you can only run as little boost as the gate spring is rated for (ie: you have a 13psi spring, you can't run less boost than that)
But to answer your question!! A Walbro 255 intank pump will do justtt fine.
I say you read up on the forced induction stickies b4 you boost your car. SO you don't make any mistakes and waste money, and most importantly you UNDERSTAND whats going on with your car.
Old Jun 22, 2010 | 07:41 PM
dancing_ninja's Avatar
Fuel:
Walbro 255 pump
ID725 Injectors
Run a Hondata S300 w/boost control.
If you're going to run 9psi-10psi max get a .4or .5 bar spring in the wastegate.
Definitely do your research.
Happy Motoring!
Old Jun 23, 2010 | 12:40 PM
julianbc2's Avatar
Originally Posted by dancing_ninja
Fuel:
Walbro 255 pump
ID725 Injectors
Happy Motoring!
thank you
MadScientistGuy
28
Nov 30, 2011 05:21 PM
hondamonkey
Aug 15, 2007 05:47 AM
black_ek
Mar 7, 2007 06:07 PM
TrumpTiteJoker
May 15, 2004 11:11 AM
Generation2
Jul 22, 2003 07:28 PM
