Boostie 2012
Old Mar 16, 2012 | 09:31 AM
  #76
speedooo's Avatar
Default Re: Boostie 2012
Great build. Nice to see somebody actually use a sensible setup...
Thermal RD 3" or Kteller 3" piping with a vibrant streetpower muffler always get my votes. Not to mention the streetpower stealth mufflers are flatblack which would match the flat black fmic.
Old Mar 16, 2012 | 10:22 AM
  #77
TheShodan's Avatar
Moderator
Originally Posted by MugenSpeclNY
I have the Sk2 Mega power R(2.75inch) on my N/A stock cam GSR. And i love the sound and the looks. I was VERY pleased on its first start up after installing (at the time) my new RMF narrow reps, 2.5 test pipe, and the mega power R. very pleased. I plan on going turbo in the probably not to close future(lol), when i do i plan on switching to the mega power RR after having my R for almost 2 years now.
When my money is right i plan on using that same turbo, everything i hear about it makes me want it more, i've dug up as many graphs as i can on it and love everything i see(mostly evo graphs not many hondas graphs out there with that turbo). Planning on going for 500Whp as a HP goal, then i plan on turning down the boost and running boost by gear with my S300 to set it up proper for street traction. I'm thinking itll prob sit around 400-450ish all said and done 4th gear, all depends on traction.
After reading this thread its making me a little unsure about my cam decision. I recently purchased a set of Sk2 Pro1's off a forum member for a very good price(BNIB). Maybe to big for my set-up? I plan on running 84mm with mid to high 9's compression. It going to be a slow process i dont make that much money so im saving everything i can, but my plan is....Buy all head components (already have cams) Sk2 pro springs/retainers,bronze guides, send out 2 PnP and valve job and freshin it up. Run the head on my stock GSR block, until funds come in to build the block, save to build block and send it out, then reassemble with my built head, run that N/a still to break it in and to continue to save money for the turbo kit. Then finally one day throw the kit on.
sorry for the wall of text, bored at work haha....
But build looks great and cant wait to see your graph, much luck to you.
p.s for the Sk2 exhausts. (personal opinion)
You never stated your turbocharger. That may help determine whether or not you have the correct camshafts or not.
Old Mar 16, 2012 | 10:47 AM
  #78
shawty22's Avatar
I think hes talking about the 5858? That would be my guess...?
Old Mar 16, 2012 | 10:48 AM
  #79
shawty22's Avatar
Originally Posted by Natural Aspirations
I ended up buying an eBay exhaust for now....
I got a 3" "Turbo" ebay exhaust for my car last year. I cut the huge fart can it came with off and put on a 3" Magnaflow muffler on it. Sounds nice and quiet, good sounding. I love it
Old Mar 16, 2012 | 10:50 AM
  #80
TheShodan's Avatar
Moderator
Gotcha. Well, it could be ok with those cams, but more than likely they are a bit too large. Its to a point of "we'll see."
Old Mar 16, 2012 | 01:55 PM
  #81
Natural Aspirations's Avatar
Umm.. exhaust? 3" with X resonator, Y piping and Z muffler..
That's what we were talking about right?
I bought the one I posted photos of, it arrived yesterday. I was pretty sure we had ended the exhaust discussion with you being sorry for my car.
Old Mar 16, 2012 | 05:13 PM
  #82
TheShodan's Avatar
Moderator
Ok. Let me rewind here...
03-15-2012 08:58 AM - when this statement was made. This statement implies that this measure was only temporary. Like I said. I always read before I make a statement the best I can.
Old Mar 16, 2012 | 05:21 PM
  #83
I have no current plans of changing it.
Old Mar 16, 2012 | 05:33 PM
  #84
TheShodan's Avatar
Moderator
ok. Consider my question moot.
Old Mar 17, 2012 | 03:55 PM
  #85
MugenSpeclNY's Avatar
sorry i didn't state which turbo but i was referring to the thread starters snail.
Old Mar 17, 2012 | 08:14 PM
  #86
ekhatch44's Avatar
it's nice seeing a local build done right...keep up the good work. Excited to see some numbers.
Old Mar 17, 2012 | 08:26 PM
  #87
ekhatch44's Avatar
....and curious as to what clutch/transmission you went with? Didn't see it mentioned yet...
Old Mar 17, 2012 | 09:29 PM
  #88
USDM R trans and CC stage 4 disc with and exedy PP.
I got the exhaust on today, the quality and fit are as good as I expected reasonably quiet.
Leaving the garage I had a very very scarry incident where the car completely died...... Had to pull off the road. Lost voltage to the ECU.... Solid CEL no fuel pump or radiator fan. Started looking for problems around the ecu and it came back when I moved the harness, moved to looking under the hood and grabbed the harness near the main ground on the thermo housing (which is tight) and it came back to life an has been fine since...
Old Mar 17, 2012 | 09:45 PM
  #89
K7-1Ktrevor's Avatar
Loved
Community Favorite
sounds like a jumper harness problem lol. I hate jumper harnesses more then you could ever imagine.
Old Mar 18, 2012 | 03:35 AM
  #90
That's possible, I ordered a new one immediately because it does have some splices. It may also be coming from the fuse box, any time I go through an automatic car wash it acts up, and this has even happened with a different engine harness.
Old Mar 18, 2012 | 05:01 AM
  #91
Cams showed up yesterday.
Unfortunately they don't match the profiles on the website so I'm trying to send them back.
Old Mar 18, 2012 | 06:43 AM
  #92
TheShodan's Avatar
Moderator
Did you not call the company you bought them from to first confirm? Perhaps they simply enclosed the wrong sheet?
Old Mar 18, 2012 | 10:01 AM
  #93
I went by their information provided on the website which should be accurate.
Old Mar 18, 2012 | 10:14 AM
  #94
2000GSRTypeR's Avatar
How do you like the type r tranny? I have a JDM 98 spec type r tranny myself.
Old Mar 18, 2012 | 12:02 PM
  #95
I can't say for sure just yet. It's great on 5psi... May run out of gear up top though. I have plans to run a 4.0 final or a gsr 4th / ls 5th in the future though.
Old Mar 18, 2012 | 01:33 PM
  #96
TheShodan's Avatar
Moderator
whelp. Website or not. if the sheet that's enclosed is not the same as the site, one of them could be wrong. Call and confirm before keeping or sending them back.. what is it with people and a phone call?
I swear, if websites went down, people act like armaggedon would be upon us..
Old Mar 18, 2012 | 01:42 PM
  #97
Ok.... I appreciate your assistance Shodan, but there is a point that it becomes you second guessing my every step. I'm a big boy and have likely been doing this as long or longer than you. I'm not at all trying to be negative toward you but "I got this"
Old Mar 18, 2012 | 01:44 PM
  #98
TheShodan's Avatar
Moderator
Do your thing.... I'm out of it.. .. Sorry I cared..
Old Mar 18, 2012 | 01:48 PM
  #99
Spawne32's Avatar
try not to over torque your oil pump bolts this time
Old Mar 18, 2012 | 01:50 PM
  #100
Tune scheduled for April 7th
