Boosted B18c1 with A/c still, problems
Old May 6, 2007 | 10:40 AM
incubusboy87's Avatar
Default Boosted B18c1 with A/c still, problems
Now that its warmed up and started to use A/C having some problems. When you driving with A/C on and you press in clutch to come to a stop, the idle will just slam down real fast and half the time kill the car. Running honda s300. Is there anything you can adjust to correct idle with A/C on. Im sure from all the extra heat its running at a high high pressure. A/C idle is corrected in your ECU right? Anyways just wondering if anyone has any ideas.
Old May 6, 2007 | 10:52 AM
Schister66's Avatar
Man U FTW
i had the same problem...rather than fixing anything i just removed the AC when i got my topmount...
Old May 6, 2007 | 10:54 AM
rainmanEK's Avatar
big strong guy
Default Re: Boosted B18c1 with A/c still, problems (incubusboy87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubusboy87 &raquo;</TD></TR><TR><TD CLASS="quote">Now that its warmed up and started to use A/C having some problems. When you driving with A/C on and you press in clutch to come to a stop, the idle will just slam down real fast and half the time kill the car. Running honda s300. Is there anything you can adjust to correct idle with A/C on. Im sure from all the extra heat its running at a high high pressure. A/C idle is corrected in your ECU right? Anyways just wondering if anyone has any ideas.</TD></TR></TABLE>
Just wondering is you have a lightend flywheel?? I noticed this happend on a car I worked on after I installed a New Clutch and Lightend flywheel.....
Eric
Old May 6, 2007 | 12:31 PM
rmcdaniels's Avatar
Mine used to do that, it was in the ECU. JDogg fixed it for me in my Hondata, not sure what he did to make it work.
Old May 6, 2007 | 06:30 PM
Default Re: Boosted B18c1 with A/c still, problems (rmcdaniels)
Ya i figured you could adjust it somehow through something in hondata. But im sure it does, but does it still seem real sluggish with the a/c on. I know its obviously going to cut hp and slow you down a bit, but just runs terrible with it on. Maybe if fix the idiling out it will fix that also. And no still have stock flywheel. Wierd how that would cause sometihng like this!
Ecky
Jun 25, 2012 02:46 PM
redboost10
Jan 20, 2007 02:22 PM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
99b18
Nov 11, 2004 05:36 AM
quik2kSi
Dec 27, 2003 09:04 AM
