Re-use Exhaust Manifold Gasket for Turbo setup?
Should i re-use my stock exhaust manifold gasket for my greddy turbo setup. i've heard my buddies tell me both ways so i was just wanting some more input from turbo guys. thanks a lot!
Re: Re-use Exhaust Manifold Gasket for Turbo setup? (Del_Slowest)
sure y not.. i used all my stock gaskets for my all four of my turbo setups.. good luck with the install..
Re: Re-use Exhaust Manifold Gasket for Turbo setup? (ALL MOTOR LS)
oh ya. I always reuse the metal ones. 2 coats of copper spray works great after cleaning both sides of the gasket, head and manifold with a wire brush or scuff wheel. never had a problem
I usually replace the gasket everytime I do a rebuild.
I have reused the same gasket before when swapping out manifolds and the seal was still perfect.
didyouhearthat
11-10-2013 08:11 PM
h22_crx
02-24-2007 05:57 AM
