Boost Sucks
Old Jun 13, 2003 | 05:24 AM
  #26
cajnatc's Avatar
Default Re: (len)
I'm running a turbonetics t3/t04b with low compression pistons on a D16Y8 and I hit full boost at 4.5 pulling hard.
Old Jun 13, 2003 | 06:46 AM
  #27
dynomax27's Avatar
Default Re: (cajnatc)
heres some pics it looks pretty clean
Old Jun 13, 2003 | 07:43 AM
  #28
Poop111444's Avatar
Default Re: (dynomax27)
man whats with that itty bitty farty ?
Old Jun 13, 2003 | 08:32 AM
  #29
DSGB.'s Avatar
Dirty Bird
Default Re: (si_mekanik)
ive heard there is a REALLY BIG diffrence in changeing a stock exahust, So if that is stock exahust, it may be your problem, Try unbkloting it and drive it.
Old Jun 13, 2003 | 10:55 AM
  #30
evoeone's Avatar
Default Re: Boost Sucks (dynomax27)
im guessing you had the tight *** t25 on before 8.5 comp? right?
now you jumped to 8.5 , not to mention a t3t4 which is humongous compared to a peezy t25, you also have a big hot side too .63,
Old Jun 13, 2003 | 01:53 PM
  #31
SOUNDEFFECTS's Avatar
Default Re: Boost Sucks (evoeone)
Ok this is what you do if you want it to make it run better:
A.Pick up a .48 a/r exhaust housing $100-$150 new
B.Drop the exhaust as much as possible (no muffler,cat,etc... or just run bigger piping back)
c.Tune it.
Old Jun 13, 2003 | 02:16 PM
  #32
GraphiteAccord's Avatar
Default Re: Boost Sucks (SOUNDEFFECTS)
What is that rubber tube coming off the centersection? Don't tell me thats the drain to the oil pan? If is, you have big problems, that is a Gravity feed line, meaning, it doesn't have pressure on it, it uses Gravity to carry the oil back ot the oil pan. Pointing up, gravity doesn't have much effect on it.
Old Jun 13, 2003 | 02:47 PM
  #33
boosted92's Avatar
Default Re: Boost Sucks (Sleeping4drLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeping4drLS &raquo;</TD></TR><TR><TD CLASS="quote">
Cheapest solution: 50-shot with a Hobbs Turbo/Nitrous Switch to turn on/off the NAAAAWZ at a certain boost pressure.</TD></TR></TABLE>
Not everyone likes to keep the bottle warm, but it works. Friend of mine with a 4.2L Stage 2 GN with a ball-bearing T76 has a single NOS fogger setup for 75 HP, window switch to turn it on @ 3000, off at 7100, WOT switch, and a hobbs switch to turn it off once he hits 22 PSI (he runs 24 PSI max) doesn't use it from a dead dig because he can build boost pretty good on the trans brake, but it's killer for getting that big huffer running from a roll, and it works fine for him on pump gas + alky injection
Or, of course, you could just go to a smaller turbo
Old Jun 13, 2003 | 09:34 PM
  #34
Midwestrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOUNDEFFECTS &raquo;</TD></TR><TR><TD CLASS="quote">Ok this is what you do if you want it to make it run better:
A. Pick up a .48 a/r exhaust housing $100-$150 new
B. Get 3" exhaust
C. Tune it.</TD></TR></TABLE>
Try what this man sugguests...
Old Jun 14, 2003 | 04:10 AM
  #35
dynomax27's Avatar
Default Re: Boost Sucks (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">
What is that rubber tube coming off the centersection? Don't tell me thats the drain to the oil pan? If is, you have big problems, that is a Gravity feed line, meaning, it doesn't have pressure on it, it uses Gravity to carry the oil back ot the oil pan. Pointing up, gravity doesn't have much effect on it.</TD></TR></TABLE>
yeah i know its bad for the oil retun line to be shooting up because the oil return needs gravity to pull it down.
Old Jun 14, 2003 | 04:18 AM
  #36
dynomax27's Avatar
Default Re: Boost Sucks (Midwestrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwestrider &raquo;</TD></TR><TR><TD CLASS="quote">
where could i get a .48 a/r exhaust housing?
Old Jun 14, 2003 | 06:34 AM
  #37
tony1's Avatar
Don't worry about buying the turbine housing seperately, you'll be buying a whole new turbo very soon if you don't fix that oil return!
Old Jun 14, 2003 | 07:00 AM
  #38
dynomax27's Avatar
Default Re: Boost Sucks (tony1)
i dont know what im gonna do cuz if i flip the turbo i'll have to redo the piping and i dont have the $$ and i dont think the turbo will fit under the hood if i flip it
the seals on the turbo are already blown so i need a rebuild asap
Old Jun 14, 2003 | 09:00 AM
  #39
DaveF's Avatar
cant you just rotate the center section, without moving either the exhaust or compressor housing??
Old Jun 14, 2003 | 10:30 AM
  #40
sivic_si's Avatar
Default Re: Boost Sucks (2.2Lcivic)
i think he is right! I believe you can rotate the center or the housings to make the return point down.
there is hope,
Josh
Old Jun 14, 2003 | 01:31 PM
  #41
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">cant you just rotate the center section, without moving either the exhaust or compressor housing??</TD></TR></TABLE>
hello, its are 1 million dollar winner...
Honestly, how about you step back and research alittle bit more? You don't know how to clock the housing, you put a huge turbo on a little motor, with lower then stock compression....just a suggestion...
Old Jun 14, 2003 | 01:45 PM
  #42
symba's Avatar
man, you are brave. you spend all that money on your car, I assume you did the install judging from the oil return line and yet you apparently didn't spend enough time researching and learning. you just bought stuff and slapped it on there. I'm not trying to be a dick but man you can cause a lot of damage by not making sure you know your $hit 100%. A turbo rebuild isn't cheap and it was just a simple error that caused it.
Old Jun 14, 2003 | 01:51 PM
  #43
Default Re: Boost Sucks (symba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by symba &raquo;</TD></TR><TR><TD CLASS="quote">man, you are brave. you spend all that money on your car, I assume you did the install judging from the oil return line and yet you apparently didn't spend enough time researching and learning. you just bought stuff and slapped it on there. I'm not trying to be a dick but man you can cause a lot of damage by not making sure you know your $hit 100%. A turbo rebuild isn't cheap and it was just a simple error that caused it. </TD></TR></TABLE>
Symba is right, i don't mean to come across as mean or anything, but its true...
Old Jun 16, 2003 | 05:00 PM
  #44
dynomax27's Avatar
yeah i know im a dumb *** cuz i blew 600 for a turbo now it needs a rebuild which is gonna be 250+
Old Jun 16, 2003 | 06:21 PM
  #45
HXMan's Avatar
Where you located in Wisconsin?
Old Jun 16, 2003 | 08:19 PM
  #46
MaxBoost's Avatar
New User
Default Re: Boost Sucks (HXMan)
First things first, fix that oil return, that's horrendous.
Next, I'd bet that if you ran open downpipe that turbo would spool 500+ rpm's earlier, a stock exhaust is very restrictive and makes lots of lag.
I would plumb a cutout into your downpipe somewhere or get a 3" exhaust, that will help the lag.
so will rebuilding the turbo and so will getting the whole motor tuned on the dyno, invest in hondata, if you already haven't, for a low-buck solution. If all of the above fails then you might want to go ahead and trade turbo's with someone.
Old Jun 16, 2003 | 08:37 PM
  #47
Muckman's Avatar
Moderator in Chief
Man what were you thinking?!
Old Jun 16, 2003 | 10:02 PM
  #48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynomax27 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i know im a dumb *** cuz i blew 600 for a turbo now it needs a rebuild which is gonna be 250+ </TD></TR></TABLE>
Honestly, find a straight T3 or something of that sort. may need a new downpipe, but it'll be worth it. then sell that turbo....
Old Jun 17, 2003 | 03:49 AM
  #49
symba's Avatar
ok, now that you've been beaten up enough about the oil line...
This is my opinion as to why you have such bad spool-up
your turbine a/r is too big - a .48a/r would work better
your compression is a little bit low - the norm is 9.0:1 to 10.0:1.(need flawless
tuning for 10.0:1)
that diy log manifoldmightbe a problem..don't know for sure without having specs but maybe its a little restrictive.
Your intercooler piping might be a little large. 2.25 all around would have been fine for you.
Now, without ripping your entire system apart, you can either just rebuild that turbo and get a smaller turbine while you're at it or you can just buy a straight t3 turbo and sell the one you have. (just let them know it needs a rebuild)
smaller turbine with rebuild may be a little cheaper than a new turbo. check out http://www.cheapturbo.com
Old Jun 17, 2003 | 04:17 AM
  #50
RGAZ's Avatar
New User
Dude, since you are going to remove that turbo immediately, here is how to clock it.
Remove the bolts holding the exhaust section and remove the snap-ring or bolts holding the compressor side and then turn them. I can't see if its snap ring or bolts, but you have to properly clock that turbo.
Yes, the hot AR is too big.
No, I don't think that manifold is a problem.
Yes, your tiny stock exhaust is a problem.
Good luck man.
Randy
projectef
Jul 3, 2007 08:35 PM
vtec25
Jun 5, 2006 12:30 AM
rastaman_ek9
Jan 4, 2005 11:15 AM
mrx
May 12, 2004 11:20 AM
FreeMyndz v.FP
Mar 21, 2002 04:36 PM
