Can i turbo my 11.6:1 compression ratio LS/VTEC????
i just got a turbo kit and would like to know would i be able to boost my set up without blowing it right away? What would be safe amount of boost? 5psi?
Any advice,opinion,comments are welcome
Thank you
Thank you
Re: Can i turbo my 11.6:1 compression ratio LS/VTEC???? (vtec25)
rods/pistons arnt that much. If your motor blows more then likely it'll mess your head up sleeves and/or turbo.
Re: (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote">im 11.3 on 6 pounds hondata and 100 octane its a blast to drive spools up the sc-61 like crazy no lag, its like an all motor car on stariods. </TD></TR></TABLE>
Damn thats high cr...you must be making a ton of power for such low boost?
Re: (darkdayz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdayz »</TD></TR><TR><TD CLASS="quote">
Damn thats high cr...you must be making a ton of power for such low boost?</TD></TR></TABLE>
ya 297 whp and 194 tq on a mustang dyno plenty for the streets
Good tuning (at least a nice engine management system with a competent tuner) and keeping the power under 300 WHP and you should be okay. I have 94 oct pump gas available locally, and I was running at 11.5:1 CR on a GSR motor w/ GT28RS @ 8 psi (286 WHP) for a good while and the engine had no problems taking it. It was only after I upped the boost to 12-14 psi that I realized the engine was kissing at detonation limit (a water injection system was installed afterwards).
Mr.Saturn
04-13-2003 11:21 PM
113, 116, 1161compression, boost, compression, cr, high, lower, ls, ratio, turbocharger, turbocharging, vtec, vtech, whp
