310cc injectors for 10 psi of boost?
i am goin to be boosten on my b18b motor and i was woundering if 310cc injectors to do up to 10 Psi at the track and 7-8 psi daily would be enough to support that or would i have to get 440 cc?
Re: 310cc injectors for 10 psi of boost? (mitchellP)
If you are using an fmu 310s should be alright, but if your using uberdata or hondata or even an afc then id get 440s.
Re: (98TEG2NV)
330c c/min / 10.5 = 31.42 lbs/hr
31.42 lbs/hr * 4 injectors * 0.9 duty / 0.50 BSFC = 226 horsepower
10 PSI ~ 120 hp * (14.7 + 10) / 14.7 ~ 201 hp (rough estimate)
If you are going to be making only 10 PSI, and assuming the stock rev limit is kept, there is no reason 330 cc/min injectors won't work. However, if good tuning or a raised rev limit raises your horsepower to more than 226, you will need more fuel.
