Boost psi w/ TT setup
Old Dec 14, 2005 | 11:30 PM
andysila's Avatar
Default Boost psi w/ TT setup
hi, my friend had a 2004 nissan 350z and he bought the greddy tt kit.
he bolted the kit on, the e-manage was suppose to be "preprogrammed" by the manufactorer. no boost controller, just e manage, NO intercooler
How do we find out what his overall PSI was when he was running the car (engine blew after 3 days when he went WOT)? If there is no boost controller, then shouldnt the turbos be running of the WG spring? the wg spring is .8-1.0 which is about 11 PSI, and since there are 2 turbos, was his total ammount of boost 22 or 11 psi?
tia.
Old Dec 14, 2005 | 11:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost psi w/ TT setup (andysila)
11
Old Dec 15, 2005 | 12:16 AM
andysila's Avatar
does that mean 11 total?
Old Dec 15, 2005 | 12:19 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (andysila)
yes
Old Dec 15, 2005 | 12:23 AM
andysila's Avatar
is it cool if u can explain how that works.
thanks
Old Dec 15, 2005 | 06:54 AM
PM-Performance's Avatar
Whats there to explain? 11PSi is 11psi, dont matter how many turbos you have. They link together one way or another.
I know on Supras they do. the outlet pipes T together and they Y pipe Y's the exhaust together.
Simple theory
Old Dec 15, 2005 | 07:42 AM
HybridKOOP's Avatar
Default Re: (itr206)
I feel for the 350Z.
Old Dec 15, 2005 | 07:51 AM
Turbo-charged's Avatar
Default Re: (HybridKOOP)
i beleive in the instructions for that kit it says like 12 times on every page to make sure you install a boost gauge before the initial test drive.
boost is measured at the manifold.....you can have 26 turbo's and 11psi will be 11psi when measured at the manifold.
how were the vaccume lines ran to the wastegate?
Old Dec 15, 2005 | 08:00 AM
m R g S r's Avatar
Default Re: (Turbo-charged)
your supposed to run vaccuum lines to the wastegates?
Old Dec 15, 2005 | 08:16 AM
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">your supposed to run vaccuum lines to the wastegates? </TD></TR></TABLE>
Na only you only run a line from WG to WG.
Old Dec 15, 2005 | 08:27 AM
B18 CYA's Avatar
if u didn't run the vacuum line properly to the wastegate u'll be hitting more than 11psi. also, who boosts without a boost gauge?
Old Dec 15, 2005 | 09:02 AM
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote"> also, who boosts without a boost gauge?</TD></TR></TABLE>
Apparently 350Z owners who can afford a $35k car and a $8k turbo kit, but not a $40 gauge. lol
Modified by itr206 at 2:03 PM 12/15/2005
Old Dec 15, 2005 | 09:39 AM
andysila's Avatar
thanks for the replies.
yea its pretty sad, no b/c, no intercooler, no boost gauge. but its a $37,000 car with a $5000 turbo kit.
I will ask about the vacuum lines when i see him later on today.
Old Dec 15, 2005 | 10:32 AM
spyz34's Avatar
First thing I bought when peicing my kit was the damn gauge. No gauge is asking for trouble. Poor 350z w/shoddy owner
Old Dec 15, 2005 | 12:08 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">if u didn't run the vacuum line properly to the wastegate u'll be hitting more than 11psi. also, who boosts without a boost gauge?</TD></TR></TABLE>
wrx's...
rudebwoy
Jan 7, 2008 01:45 PM
AznInvasion
Dec 12, 2004 04:14 AM
99lspwr
Mar 18, 2004 02:07 PM
b18c195
Jan 11, 2004 02:03 PM
