Boost problems with teg
Old Oct 21, 2012 | 05:39 AM
Begley's Avatar
Default Boost problems with teg
Hi Guy's need some advice on boost problems on my turbo build.
Right were to start,i build a turbo teg with a GT35r turbo with a Tial 38mm waste gate.I had to do run in miles on the engine cause it was completely built.After i done the run in miles i went to get it mapped an came across there was a boost problem.The waste gate had been opening but now its not.My tunning company said it was the turbo,but i got it check an its in perfect condition.Im running a Greddy boost controler an it is working ok.I done a vacum test on the waste gate an on the top of the waste gate it was holding boost but the middle vacum pipe wasnt,should this be holding boost to..Please i need help quick.Cheers
Old Oct 21, 2012 | 03:59 PM
HYREV2NR's Avatar
Default Re: Boost problems with teg
Friend you'll probably get a quicker response if this was posted in the forced induction forum.
Old Oct 21, 2012 | 07:37 PM
Todd00's Avatar
I said I don't want a title!
Yeah, there is probably only 3-4 people in this forum that could maybe help. Try the FI forum.
Old Oct 22, 2012 | 08:02 AM
Begley's Avatar
Sorry Guys,thanks for moving it for me.Can any 1 help me with this 1
Old Oct 22, 2012 | 08:20 AM
sp00led's Avatar
I'm not sure about your setup but I've got a TIAL gate that has two fittings on it. I ran one line from the intake manifold to a MAC solenoid. There is a tee fitting on the main line before the solenoid that connects to the wastegate. Really not that much to it. If you hook it up backwards then the wastegate won't open and it should hit boost cut.
I'm not sure if Greddy solenoids fail open (like the GM solenoids) or closed. You might try bypassing it and run just the wastegate spring until you sort things out.
Old Oct 23, 2012 | 12:55 PM
Begley's Avatar
Thanks for the info mate..Think its something wrong with the turbo,its no building boost for some reason.
Old Oct 23, 2012 | 01:16 PM
sp00led's Avatar
Have you tried to spin the compressor wheel? I killed a GT3076R not long ago. It boosted on the way to work and then wouldn't on the way home. Pulled the intake to find that the compressor wheel was seized. Had to replace the CHRA.
Old Oct 24, 2012 | 10:55 AM
Begley's Avatar
Na mate the compressor wheel is in perfect order on both side's.The turbo just doesnt want to boost for some reason..The car is fully built for 800bhp but cant spool a turbo? I really need help.
Old Oct 24, 2012 | 11:50 AM
Hyper16-Johnny's Avatar
Sounds like you have a boost leak somewhere. Check your couplers, piping, turbo manifold, etc for any leaks.
Old Oct 25, 2012 | 11:21 AM
Begley's Avatar
Mate took the intercooler pipe of the bottom of the turbo an put my hand over the hole to see if it would build boost,stll nothing..?
millsd4
Apr 8, 2009 04:29 AM
angela_itr
Dec 18, 2005 06:38 AM
BlownBlackSi
Nov 7, 2005 08:28 PM
bodea_florian
Aug 25, 2004 06:54 PM
lvf03
Mar 13, 2004 01:57 PM
