B17 turbo build working progress
Old Aug 5, 2012 | 05:30 AM
skaraider's Avatar
Default B17 turbo build working progress
Old Aug 5, 2012 | 05:35 AM
skaraider's Avatar
Default Re: B17 turbo build working progress
Old Aug 5, 2012 | 05:37 AM
skaraider's Avatar
Old Aug 5, 2012 | 05:39 AM
skaraider's Avatar
More to come tonight, Just did the wire tuck, and got a carbon fiber hood. Putting oilcooler on also tonight and then it heads to the dyno Thursday
Old Aug 5, 2012 | 05:53 AM
skaraider's Avatar
and yes don't worry about my intercooler pipes on the front, i did recut them and size them down to fit closer to the frame, its a hard fitmit with those foglights.
Old Aug 5, 2012 | 05:55 AM
skaraider's Avatar
Also switched the interior out to black everything but the dash, didn't take pictures of that though
Old Aug 5, 2012 | 07:07 AM
nealnanoHX's Avatar
Wow an Ebay turbo kit and no timing belt covers at all..............
Old Aug 5, 2012 | 07:32 AM
skaraider's Avatar
Also replaced the remain seal while i had the tranny off
Old Aug 6, 2012 | 02:52 AM
skaraider's Avatar
Old Aug 6, 2012 | 06:54 AM
kyden's Avatar
uh.. where's your dump tube?
Old Aug 6, 2012 | 07:15 AM
skaraider's Avatar
its coming next, only reason y I got the CF hood was because i traded it for my old D series block.
When i get to the tune shop on thursday im going to see if he has any in stock.
Old Aug 6, 2012 | 09:14 AM
nealnanoHX's Avatar
And you are diving it untuned!!!!!!!!
Old Aug 6, 2012 | 09:18 AM
Aradin's Avatar
Premium Member
You're gonna burn right through that oil feed without a dump tube.
Old Aug 6, 2012 | 09:20 AM
skaraider's Avatar
it will be fine as long as im not doggin it, im driving it 2 hrs thursday to the dyno untill then its going to remain parked. Yeah u might be right on burning it, ill grab my fitting and head to the weld shop before i roll out to the dyno
Old Aug 12, 2012 | 05:02 AM
skaraider's Avatar
Some complications on holding the boost, so im currently working on my leaks then ill take it back, also putting arp studs in it before i head back down there and a new head gasket.
Old Aug 12, 2012 | 05:56 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
keep us posted, nice work so far
Old Aug 12, 2012 | 06:04 AM
skaraider's Avatar
will do, it may be awhile now trans went out this morning on the way to work
Thanks over the next few months ill be upgrading to a tial wastegate and a differnt turbo possibly. and now the transmission.
Old Aug 21, 2012 | 03:32 AM
skaraider's Avatar
Finally got another trans, putting it together and after the painting of the engine bay ill put it back in.
Going to clean , prep and paint, the Front clip. Will keep updating through the week.
Old Aug 21, 2012 | 03:36 AM
skaraider's Avatar
Also doing, Motor mounts, front suspension, changing out the Crap OBX Wastegate to a Tial WG, and possible turbo. Adding in a Oil cooler as well.
Old Aug 24, 2012 | 05:47 AM
skaraider's Avatar
Ording, motor mounts, arp head bolts, cometic head gasket , and tial f38 wastegate next week... get everything back in and return to the dyno once more
Old Aug 24, 2012 | 05:50 AM
skaraider's Avatar
Old Aug 27, 2012 | 12:37 PM
LogicMotorsports.com's Avatar
Looks like your off to a good start, in for more. Engine bay looks great! I think youll be happy with those new parts.
Thanks,
Devin@Logic Motorsports
Old Aug 29, 2012 | 10:03 AM
skaraider's Avatar
Thanks,
Here is a picture of my old trans and why i can't use it anymore
Old Sep 1, 2012 | 06:35 AM
skaraider's Avatar
Old Sep 1, 2012 | 06:41 AM
skaraider's Avatar
