Boost gauge/controller
Old Sep 11, 2002 | 07:44 PM
Kamin's Avatar
Default Boost gauge/controller
Ok i saw a topic a while ago that asked is it safe to just run a wastegate with no boost controller or boost gauge.
im running short on funds for this and i would be happy just running 6psi (tial .45bar wastegate, thanks viren) untill i can afford good gauges and a profec b
so is it safe to boost?
Old Sep 11, 2002 | 08:11 PM
98civicEX's Avatar
Default Re: Boost gauge/controller (KAMiN)
at least get a boost gauge, $60 at most i believe.
Old Sep 11, 2002 | 08:13 PM
Ivan's Avatar
senior gold member
I would atleast get a boost gauge. I found one at a local v8 shop for 35 bucks. I'm running a boost controller but I'm just running of thw wg cause Idon't wanna go over 5 psi until I upgrade the fuel.
Old Sep 11, 2002 | 08:21 PM
Ri5e's Avatar
Default Re: Boost gauge/controller (Ivan)
At least get a boost gauge...
Old Sep 11, 2002 | 08:23 PM
Kamin's Avatar
Default Re: Boost gauge/controller (CRV Monster)
dont the cheap ones that work on vacuum kinda suck tho?
like the longer the tube the less accurate it is?
Old Sep 11, 2002 | 08:27 PM
Ivan's Avatar
senior gold member
you're right on that one. My wg spring is 5.5 and my boost gauge reads close to 6.
Old Sep 11, 2002 | 08:28 PM
cock head's Avatar
I got mine for 12 dollars, its just boost but works really good?
Old Sep 11, 2002 | 08:46 PM
Danger's Avatar
you should atleast get a boost gauge . you could find a used one for like $20 if you search around . never know if the wastegate is gonna spike or not .
dan_w_82
Mar 28, 2006 11:37 AM
Sprayin_civic
Aug 26, 2004 10:35 AM
boostdB16a
Jul 9, 2003 04:48 PM
CRVRX
Nov 16, 2002 08:03 PM
