Boost problem
Old Mar 27, 2009 | 07:49 PM
93b20z's Avatar
Icon2 Boost problem
well this is the problem.. my gauge reads just fine but i don't feel that jerk from the "force"..
i had taken the manifold off due to the fact that it was cracked.. had it welded.. and put back on... and now it doesn't boost.. like i said gauge reads fine, but there seems to be a leak... seems like when it boosts, it just gets dumped out of the wastepipe... HELP???!!.. anything will help.. do i need to replace gaskets??.. find leaks??... what is the most efficient way to find the leaks... ??
Old Mar 28, 2009 | 07:13 AM
Silva Bullit DC4's Avatar
Default Re: Boost problem
Search "boost leak". I had a leak too, and I found a thread that someone posted up how to make a homemade leak tester from Home Depot items. Works pretty good too, I found THREE leaks in my system.
Old Mar 28, 2009 | 02:33 PM
93b20z's Avatar
thanks.... anything else is welcome to add
Old Mar 28, 2009 | 05:40 PM
What brand, model and condition is your clutch in? Could also be slipping...
Old Mar 30, 2009 | 07:33 PM
93b20z's Avatar
i've found a few ways to do the test.. whats the easiest?? and what do i need to plug up/block off, if i use pressure to the end of the intercooler up??... making sure i don't blow anything while i'm doing this test....
Old Mar 31, 2009 | 06:07 PM
The most effective way is to start at the compressor inlet. Here is how I made mine...
First, I took a 2" PVC end cap (Home Depot), drilled and tapped a hole for a pipe nipple (I used a 1/4:18 tapered pipe nipple), then added a male connector (like found on impact wrenches). Then I took a female connector, and added it to 3' of hose. Then, I added a valve stem to the other end for my air supply, and clamped it to seal the air in.
If your turbo compressor is an E housing, use a 2.5" silicone coupler (they flex better), and push the end of the end cap into it, and hose clamp it so its nice and tight. Take the other end of the silicone coupler, and wiggle it on to the compressor inlet of your turbo, and hose clamp that as well so the whole thing doesnt leak. (if you have an S over, you'll need a 2.5" to 3 or 4" reducer coupler)
With the car off, connect the hose connectors together, supply air through the hose, and watch your boost gauge (8 to 10 psi will do). Disconnect the air supply, and listen for leaks. Real simple, but real effective! ;-)
Old Apr 2, 2009 | 07:15 AM
93b20z's Avatar
i dont need to cover/ block any lines at all correct??..
Old Apr 2, 2009 | 11:53 AM
No.
samualjoseph
Oct 8, 2009 08:02 AM
ragethemachine86
Sep 12, 2006 07:58 PM
StolenTeg
Mar 17, 2006 10:41 AM
cajnatc
Jun 13, 2003 04:18 AM
genop
Mar 31, 2003 06:04 PM
