Boost Problem
Old Dec 10, 2005 | 03:19 PM
civicliveit's Avatar
Default Boost Problem
I have a 2000 Si B16 with a drag gen 3 kit on it. I have been running it for the past 3 years with no problems. I just recently had the bolt for the turbo break off so i took the manifold and turbo off and put all new gaskets and bolts in the setup. I also just recnetly put a AEBS Intake on the car. My problem is this.
I have tried to set my boost level using the deltagate wastegate with the 7 psi spring. It will not move at all. the wierd thing is that it held at 7 psi for the last 3 years and now since i took everything apart, it wont ge below 11. Has anyone heard of the wastegates going bad? i took it apart and the spring is still in one piece and the gasket looks good. I have no idea what could be causeing this problem.
Thanks in Advance
Old Dec 10, 2005 | 03:42 PM
yee SERIOUS's Avatar
deltagate?
Old Dec 10, 2005 | 03:43 PM
Default Re: (undercoverdc2)
yeah i have the turbonetices deltagate wastegate
Old Dec 10, 2005 | 05:48 PM
DC4cedInducted's Avatar
Default Re: (civicliveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have the turbonetices deltagate wastegate</TD></TR></TABLE>
problem = deltagate wastegate
solution = tial 35/38mm wastegate
Old Dec 11, 2005 | 03:23 PM
Default Re: Boost Problem (civicliveit)
well could it be a boost issue being that i changed out the intake manifold? bc i can hear the wastegate open right at 11 psi ?
Old Dec 12, 2005 | 07:00 PM
no one else has ne thing to say about it?
Old Dec 12, 2005 | 07:24 PM
Trailz-EX's Avatar
sounds like unless your vac/press hose that operates the wastegate has a hole or got pinched off or disconnected somewhere then its the spring in the wastegate or the whole wastegate it self. if its opening at 11psi the exhaust pressure might be just over taking th gate and forcing it open, if your have a small exhaust side on your turbo. i would check the hose.
if your hose is in tack and hooked up, look into investing in a new spring or watse gate
Old Dec 12, 2005 | 08:34 PM
tallyturbo's Avatar
Default Re: Boost Problem (Trailz-EX)
i have heard alot about the deltagate's boost creep
do what i did and get a tial 38mm
Old Dec 13, 2005 | 05:27 AM
dpetro1's Avatar
where are you getting the boost signal from? its seems like too big of a coinsedence that the wastegate failed right when you decided to change your IM. i would check all the lines, are you using a boost controller at all?
Old Dec 13, 2005 | 02:53 PM
Default Re: Boost Problem (dpetro1)
i actually changed my vacuum reference off the turbo to the back of the intake manifold. Its actually the same piece of hose i use to go to my boost gauge too and that doesnt fluctuate at all so idk. And im not using a boost controller at all. im just running off the wastegate.
Old Dec 13, 2005 | 03:15 PM
515blue2kSi's Avatar
Try hooking the wastegate vacuum line directly to the compressor housing rather than letting it come from the intake manifold. Dont Tee anything off the line from the turbo to the wastegate. This might fix your problem. If that doesnt work, take apart the wastegate and inspect the skirt and housing for any cracks. If you still have no luck then a new Tial 38 mm gets my vote.
Old Dec 13, 2005 | 07:59 PM
Default Re: Boost Problem (515blue2kSi)
i have torn apart the wastegate and everything looks good in there. so idk, ill prob replace all my hoses with new ones this weekend and see what happens.
Old Dec 15, 2005 | 07:44 PM
the car pulses when it idles too so im thinkin it could be a vacuum leak
Old Dec 16, 2005 | 06:13 AM
dpetro1's Avatar
yeah if idle is weird after the IM install then you should check for vacuum leaks, i dunno much about the AEBS IMs but did you hook up the iacv and everything properly?
Old Dec 16, 2005 | 02:55 PM
yeah, everything is hooked up like the stock mani was. so it must be a vacuum leak
fasterthenU
Sep 14, 2007 12:06 AM
Paolo
Jan 31, 2007 03:12 PM
crazyimport
Sep 1, 2005 11:03 AM
Rob!
Oct 26, 2004 08:00 AM
Lei Siew Long
May 12, 2002 05:43 PM
