Tial WG problem..
Old Aug 30, 2005 | 08:11 PM
crazyimport's Avatar
Default Tial WG problem..
Well i was having huge spiking problems before. So i changed my shitty drag manifold out and now i have a inline pro mani. Everythign seemed to be ok on the street. only boosting to 10psi to make sure it wasnt spiking anymore
Well i went back to the dyno to get tuned and basically its not spiking anymore it is regulating the boost now fine. No spikes
BUT
it isnt holding the boost right its up down up down up down
going vrom pshh vrrom pssh. (but not spiking over the set psi on the boost controller)
I took my WG apart
and baam i find this
I think this is my problem the diaphram is not staying seated on the bottom of the wg its moving up with the valve.
how can i fix this now? Anyone had this problem before?
Thanks
Justin
Modified by crazyimport at 6:48 AM 8/31/2005
Old Aug 30, 2005 | 08:24 PM
dunkd's Avatar
Only help from me would be to just talk to Tial directly instead of listening to other peoples advice - it seems to work better for me when I have problems with things that are not sposed to break.
http://www.tialsport.com/
Old Aug 30, 2005 | 08:28 PM
Default Re: (dunkd)
thanks man.
This year has just been a freaking headache i havent even ran the car yet at the track and its SEPTEMBER
P.s
love your car
Old Aug 30, 2005 | 08:32 PM
dunkd's Avatar
thanks - yah believe me I went through my share of problems... just stick with it and dont take any shortcuts
Old Aug 30, 2005 | 09:06 PM
Default Re: (dunkd)
anyone have any suggestions i what i can do to hold it down?
do you think this is the root of my problem ?
Old Aug 30, 2005 | 09:14 PM
Default Re: (crazyimport)
is that diaphram supposed to move up and down with the valve???
Old Aug 30, 2005 | 09:40 PM
TurboTegB18c's Avatar
What boost controller are u running? If you disconnect the boost controller, does it still do it? It sounds like a problem in the boost controller setting somewhere.
Old Aug 30, 2005 | 09:46 PM
Default Re: (TurboTegB18c)
boost controller is holding the boost fine at the desired psi. not goign above it.
Blitz SBC i-D is what im running
Old Aug 30, 2005 | 10:24 PM
igy's Avatar
igy
Doesn't look like anything is wrong from the picture. The top that you removed actually sandwich's the diaphram in the grove of the bottom. Just stick the diaphram back in the groove and bolt the top back down, then blow in the side port and see if it holds pressure. If the diaphram has a tear then you could have a problem, but the problem would be overboosting. There was a spring in there also right?
Old Aug 30, 2005 | 10:34 PM
Default Re: (igy)
ah ok.. so the top peice will hold that bottom diaphragm peice into place so it wont move up
i think i might of figured out what the problem was
The valve was not sittign properly (that just started when i got to the dyno)
I think the little screws came lose a bit and the valve moved up a bit.
Now boost will not build up correctly when there is not a perfect seal right?
This is probably why i was losing boost and then gaining it back at higher rpms.
What do you think ?
Old Aug 30, 2005 | 10:38 PM
You have a set psi on teh boost controller and you also have a warning on it. Try turning the warning up, you also have a boost correction on there i believe where it'll try to correct overboost from your warning. I definately think it's in the boost controller. Had this problem before tuning one of my buddies car with ths sbc-id Go back and check the settings, particularly the warning. Paul
Old Aug 30, 2005 | 10:51 PM
thanks... its set at 15psi and the gain is set at 90.
Old Aug 30, 2005 | 10:55 PM
igy's Avatar
igy
Yes, if the set screws come lose and the valve doesn't seat you would have a problem building boost. The end of the valve actually has a grove that the 3 set screws go into.
Old Aug 30, 2005 | 11:18 PM
Default Re: (igy)
yup it has a grove that it goes into. i think they just came lose.. and the valve moved up not making a complete seal because it was leaking at idle.
Now there is a screw on the nut. What is this for ?
Old Aug 31, 2005 | 11:45 AM
vtec.dc2's Avatar
Default Re: Tial WG problem.. (crazyimport)
from pictures your watstegate looks fine.. tears in diaphragm will cause overboost, same goes for sligthly loose vacuum connections to wastegate. does your boost controller has overboost feature? it might be that warning psi is set at 10psi, when it reaches that it pulls back.. just a guess.
Old Aug 31, 2005 | 12:09 PM
PM-Performance's Avatar
Default Re: Tial WG problem.. (vtec.dc2)
Yea I say it looks fine.
It should seat in a little lip. And then when the spring and top hat go over it that should hold it down from fluttering.
Maybe spring pressure is weak? Boost controller probs?
Try running without the boost controller hooked up at all.
Old Aug 31, 2005 | 12:58 PM
yee SERIOUS's Avatar
is that clubsi i see in the background. lol
Old Aug 31, 2005 | 02:07 PM
DaveF's Avatar
Default Re: Tial WG problem.. (itr206)
excuse me if im wrong.....
but shouldnt that diaphram have a lip on it, that gets bolted between the 2 halves?????
Old Aug 31, 2005 | 02:22 PM
Default Re: (LiTtOGPiMp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiTtOGPiMp &raquo;</TD></TR><TR><TD CLASS="quote">is that clubsi i see in the background. lol </TD></TR></TABLE>
lol yes
and yes it has a lip it gets clamped by the top peice.
i made a fix. i put in a small washer in the top half where the valve goes into.
So it cant move up at all. I put it all back together and bam works fine
Old Aug 31, 2005 | 03:40 PM
see but im still having the same problem as before...
this was a 4th gear pull see how its not staying constant at 10psi.. its going up down up down up down.
Old Aug 31, 2005 | 04:12 PM
BoostedCivicSedan's Avatar
you mentioned before that your gain was set at 90. Change that. Set it at 50 or lower. that little spike you have in the beginning of boost where it goes to 11 or 12 psi for a sec, is caused by the gain being too high... This could also cause the inconsistincies that you are having while in boost.. Hope that helps...
(By the way, I have an SBC-id too, so I know these things )
Old Aug 31, 2005 | 09:35 PM
Default Re: (BoostedCivicSedan)
sweet man thanks ill try it out. what other settings do you have setup on it?
im using tial 38mm
i also heard that with the tial wg u should have it set with the internal wg not external?
Old Sep 1, 2005 | 11:03 AM
vtec.dc2's Avatar
mine is set at zero gain, maybe thats the problem with your settings, the gain makes it spike in beginning and then go back to set level.
R.A.T.
Apr 8, 2009 05:43 PM
krazyhmongboi
Jul 6, 2006 08:22 AM
Type-ARR
Jun 26, 2003 05:29 PM
xrtdac
Sep 26, 2002 10:18 AM
Lei Siew Long
May 12, 2002 05:43 PM
