boost on low compression vs. high compression
Old Jan 6, 2005 | 01:11 PM
ramennoodles's Avatar
Default boost on low compression vs. high compression
would a motor running low boost and high compression have a better low end response than a motor running high boost and low compression?
Old Jan 6, 2005 | 01:23 PM
ATS*Mark's Avatar
OG triple OG
Default Re: boost on low compression vs. high compression (600gixxer)
higher compression will have a better responce.
Old Jan 6, 2005 | 01:24 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 600gixxer &raquo;</TD></TR><TR><TD CLASS="quote">would a motor running low boost and high compression have a better low end response than a motor running high boost and low compression?</TD></TR></TABLE>
The high compression setup will have more power out of boost.
Old Jan 6, 2005 | 01:31 PM
b16sedan's Avatar
Default Re: boost on low compression vs. high compression (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
The high compression setup will have more power out of boost.</TD></TR></TABLE>
That's what I need to make my way down to the super market to buy milk.
"Wow, thank god we had 100 horsepower at part throttle back there instead of 96 horsepower at part throttle, that full point of compression made the difference between life and death!"
I have friends who swear by high compression turbo setups because it improves their "off boost response", but I would rather have more power blasting around at WOT when I want lots of power, than having a few more horsepower at part throttle to lug me around town.
Old Jan 6, 2005 | 01:34 PM
Drag_On's Avatar
we're not REALLY going to talk about this again are we?
Old Jan 6, 2005 | 01:35 PM
RyanEJ8's Avatar
Default Re: boost on low compression vs. high compression (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">
I have friends who swear by high compression turbo setups because it improves their "off boost response", but I would rather have more power blasting around at WOT when I want lots of power, than having a few more horsepower at part throttle to lug me around town. </TD></TR></TABLE>
He asked for an answer to his question, not an opinion.
Drag_On's Avatar
http://forums.probetalk.com/showthread.php?t=52029
Compression vs. Boost -- has nothing to do with Hondas- but the theories are correct. Lock this thread.
b16sedan's Avatar
Default Re: (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">we're not REALLY going to talk about this again are we?</TD></TR></TABLE>
It's a war of attrition, y'heard?
Old Jan 6, 2005 | 01:41 PM
DefiantGSR's Avatar
Default Re: (b16coupe)
uno mas!
Old Jan 6, 2005 | 01:55 PM
markdman's Avatar
As to what is better, its all in what you prefer. Low compression with 10lbs will make more peak hp than high compression with 10lbs. i know this doesnt really answer your question. Because with more volume in the cylinder, the more air/fuel mixture can be compressed, thus more output of power per stroke.
Old Jan 6, 2005 | 02:02 PM
RyanEJ8's Avatar
Default Re: (markdman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markdman &raquo;</TD></TR><TR><TD CLASS="quote">As to what is better, its all in what you prefer. Low compression with 10lbs will make more peak hp than high compression with 10lbs. i know this doesnt really answer your question. Because with more volume in the cylinder, the more air/fuel mixture can be compressed, thus more output of power per stroke.</TD></TR></TABLE>
You got that backwards buddy. High compression and 10psi will make more peak power than low compression and 10psi, assuming the same turbo.
white2draccord
Apr 28, 2008 03:26 AM
spurge
Mar 23, 2006 10:39 AM
Silverbullet86
Feb 10, 2006 04:12 PM
TehMoonRulz
May 16, 2005 01:15 PM
Black R
Mar 20, 2005 03:24 PM
