low compression with boost VS higher compression with less boost
Old Feb 10, 2006 | 03:59 PM
Silverbullet86's Avatar
Default low compression with boost VS higher compression with less boost
You Honda guys probably have to deal with this situation since your motors all come from factory with somewhat high compression, so i decided to make a thread here. I'm curious to learn a little more about power comparison of having low compression motor with a set amount of boost VS the same motor with slightly higher compression but pushin less boost. Anyone have any good articles on this?
Old Feb 10, 2006 | 04:12 PM
adseguy's Avatar
Default Re: low compression with boost VS higher compression with less boost (Silverbullet86)
Your search for high compression returned 95 results
Use the search. It's really preferance and $ issues here. Either way will produce horsepower safely with the corret gas
white2draccord
Apr 28, 2008 03:26 AM
slowcrx954
Nov 23, 2006 07:49 AM
chriskona
Sep 25, 2006 07:34 AM
TehMoonRulz
May 16, 2005 01:15 PM
ramennoodles
Jan 6, 2005 02:02 PM
