What RPM do you see full boost?
Also, what turbo are you running, and if you could do it over again...would you go with a bigger or small turbo?
Re: What RPM do you see full boost? (1990hondaHF)
6.5 psi @ 2500rpm on d16z, nissan t3, a little bigger like a 60 trim or something but i haven't run more boost yet so i'm not sure
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: What RPM do you see full boost? (legendboy)
I'm only running 5psi, full boost comes at 3500rpm. I rather like the sizing of my turbo.. Yeah, I would get it again if I had to choose.
Re: What RPM do you see full boost? (Snafu-Si)
greddy on d15y5 boost starts at 2800 full boost by 3400
going with a 3" downpipe and boost controller so spool time should decrease a bit.
Re: What RPM do you see full boost? (Accord94DX)
sc61 on a gsr.. 6psi at 4000rpm.. full 3" exhaust is a must and I would pick the same turbo if I was doing it again..
Re: What RPM do you see full boost? (Mikeyslude)
how come i dont hit 9lbs until like 8k rpm?
i have a b16 motor, gsr tranny and a t3t4oe 57 trim.
this normal for me?
this normal for me?
Re: What RPM do you see full boost? (chameleon)
on a saab T3 on a gsr i had 10psi by 2200rpms. i was always boosting, even highway driving, up a slight hill it would start building boost.
Re: What RPM do you see full boost? (turbodGSR)
I start seeing boost a little under 3k and full bost a little under 5k ,
im running a garret t3/04e 60trim compressor, 82 turbine, stage 3 wheel
chamaleon, most likelly u have boost leack(s) somewhere.
check all ur fittings i have a small leack that made my spool start at 3500 and full boost by 4krpm.. fixed teh boost and made a big dif.
Re: What RPM do you see full boost? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">I start seeing boost a little under 3k and full bost a little under 5k ,
im running a garret t3/04e 60trim compressor, 82 turbine, stage 3 wheel</TD></TR></TABLE>
about 500rpm sooner with a .63 ar
Re: What RPM do you see full boost? (MiraiZ)
i start building 4lbs about 4k and it climbs to 9lbs by 8k rpm, i dont hit 9lbs @ 5k or anything, if i did that would rock .. i dont think i have a leak anywhere, if i do what am i looking for ?
weird, i used to hit 7.5 psi by 3700 on my 2.25 inch greddy exhaust
this was on a t3/t04e .63 a/r 57 trim 4 bolt
3400 rpms w/ open downpipe
check all ur fittings. where ur tubes attaches to each other.. an other place is the air temp sensor. if you have that hole and sensor there, remove the sensor and cover that hole.
check also ur waste gate and blowoff valve, if they are new and havent been tampered with then concentrate on the leaks from the fittings.
Modified by kamaleon at 10:30 AM 8/4/2003
Re: What RPM do you see full boost? (kamaleon)
i have a 57trim 60a/r, 3" downpipe, 3" ehxaust and 2.5 intercooler piping.
its on a b16 motor.. i have an XS manual boost controller and i hit 9lbs @ like 8000rpm and it starts building 4lbs at 4000rpm.
