is this normal?
Old May 29, 2002 | 06:32 PM
quikrpm'z's Avatar
Default is this normal?
right before reaching full boost the needle starts fluttering back and forth. Usually i just i take the foot off the pedal, im afraid of boost spike. What do u guys see on your gauges when u reach full boost?
Old May 29, 2002 | 06:53 PM
sushibug's Avatar
Default Re: is this normal? (quikrpm)
i have a shitty pos second hand boost gauge i got for free. and it is always off by 1psi. but it doesnt do what you described. sometimes it wiggles a little at idle in vacuum, thats it.
Old May 29, 2002 | 06:58 PM
PrecisionH23a's Avatar
are you running a boost controller?
Old May 29, 2002 | 07:51 PM
shadowdawn's Avatar
Default Re: is this normal? (GudeH23a)
I have a greddy 52mm I dunno if its reading 100% correct, but it definatly doesn't wiggle at all, its very steady. It was also used, and I had to fabricate the harness that goes to the black box where the vacum line plugs in (that was fun).
Old May 29, 2002 | 09:59 PM
quikrpm'z's Avatar
no boost controler. i have a deltagate wg with a 7lb spring. Just to reiterate what im seeing on the gauge, right before the gauge needle hits .5bar it starts vibrating back and forth.
what do u guys see on your gauge when your approaching and when u hit full boost?
Old May 29, 2002 | 10:13 PM
93LSivic's Avatar
Probably that POS deltagate.
Check over all your vacuum lines. Try to get a dedicated line for the boost gauge.
CivicDude2k4
Jul 31, 2006 08:18 AM
turbonitrousgsr
Oct 6, 2003 06:54 AM
JDM_EH2
Sep 18, 2003 09:10 AM
b18tdelsol
May 18, 2002 11:46 AM
