Autometer Digital Boost gauge question
Old Jul 8, 2009 | 04:59 AM
blazin99si's Avatar
Default Autometer Digital Boost gauge question
What's up people need some help here and I apologize for the noob question (I've searched to no avail). The install instructions state that the power wire needs to be connected to a switched +12 volt source that maintains power during engine cranking. I have my wideband going to the fuse for the radio and that cuts out during cranking so any suggestions?
Old Jul 8, 2009 | 10:03 AM
blazin99si's Avatar
Default Re: Autometer Digital Boost gauge question
Here's a link to the install instructions: http://autometer.com/productPDF/1236.pdf
Old Jul 8, 2009 | 10:19 AM
tegman23's Avatar
I dont think it really matters man...Its just the boost gauge doesnt really need to be on during cranking...Just hook it to somthing that turns on with the ignition in the fues box there..
Old Jul 8, 2009 | 12:53 PM
EFbomb's Avatar
I see what you're saying now.
I'd reccomend using a power distribution block, similar to ones used for car audio.
I also use a power distrubution block off the ignition wire for all my switched acessories.
much cleaner/safer than jumping onto the fuse panel or splicing your ignition wire 5 or 6 times.
The blocks i use i acutally got from an electrical contractor supply, they are used in home wiring. I believe they are called multi tap connectors
http://www.panduit.com/Products/Prod...0535%203003652
Old Jul 8, 2009 | 09:50 PM
blazin99si's Avatar
Cool I see what your saying I'm gonna go with that thanks for the advice. Do you know which color wire off the ignition I'd splice into?
Old Jul 9, 2009 | 10:43 AM
EFbomb's Avatar
I believe its the white with red stripe, thicker gauge wire than the rest of them ... but i could be wrong because its been a while. Might want to take a look at the manual or get a voltmeter and check before you splice in.
blazin99si
Jul 10, 2009 10:18 AM
da_ska
May 31, 2009 07:24 AM
IIVIIoOkY
Apr 30, 2007 11:28 PM
Benjithx
Dec 15, 2004 12:40 PM
grnsol
Audio / Security / Video
Mar 1, 2002 07:17 PM
