boost falling out???
Old May 14, 2002 | 06:13 AM
TurbodCX's Avatar
Default boost falling out???
do any of you guys have this problem, ok lets say i have the throttle floored, and i am at redline(7800) and i let up just enough to shift to second, then my car falls out of boost and has to rebuild boost again from like the 3 psi all the way back up to 16psi, is this normal or is this some sort of compressor surge??
i have tried to adjust the BOV from real tight to real loose and all in between.
all help is appreciated
thanks
brian
Old May 14, 2002 | 06:35 AM
c_penson's Avatar
Default Re: boost falling out??? (TurbodCX)
Maybe some of the rubber joints in you piping are broken or the diafram of your wastegage is busted
Old May 14, 2002 | 06:41 AM
TurbodCX's Avatar
Default Re: boost falling out??? (c_penson)
so it should not lose boost inbetween shifts?? thanks foe helping me to man..
this is really bothering me. i need HELP!!
Old May 14, 2002 | 07:20 AM
PrecisionH23a's Avatar
you will drop boost between shifts, but not for long at all. it will spool back up quite quickly. hondata has an option on it (i am not too familiar with it, if i am incorrect please correct me) that lets you shift and keeps your TB open, WOT shifting or something along those lines....
Old May 14, 2002 | 07:40 AM
TurbodCX's Avatar
Default Re: boost falling out??? (GudeH23a)
well mine drops completely out of boost, and takes quit abit of time to make it bak up.... could it be the damn DELTAGATE??? will a TIAL make this go away?? i am crrently using TURBO X's boost controller........ could this do this??
brian
Old May 14, 2002 | 09:15 AM
TurbodCX's Avatar
no one else has had this prob??? will a tail fix it??
brian
Old May 14, 2002 | 09:24 AM
Doodoo's Avatar
Looks like a leak somewhere to me. I usually can tell if the piping is leaking by holding at a certain boost low level and watching if it falls off or stays steady. Be careful, if you stay in boost in one gear too long you can surge.
Old May 14, 2002 | 12:19 PM
noel's Avatar
Default Re: boost falling out??? (Doodoo)
DooDoo,
Can you explain what you mean by "if you stay in boost in one gear too long you can surge" that brings up lots of questions on my end like what happens when you're driving down the highway and your boosting.
Thanks,
Noel
Old May 22, 2002 | 01:58 PM
c_penson's Avatar
I tried my brothers tial on my car (i have deltagate) when my brother was fixing this oil return line and the spool up was the same, nothing changed.
Old May 22, 2002 | 03:01 PM
Doodoo's Avatar
Default Re: boost falling out??? (noel)
What I mean is if you are entering say the freeway. You are in fourth and you are waiting for the right spot to cut in. You hold your revs about 4000rpms just before you floor it to jump in the hole you see. Then you can surge your turbo. It makes a wicked sound. Shuuu Shuuu Shuuu
bads2k
Jun 8, 2011 05:32 AM
civic-8442-
May 21, 2008 10:35 AM
crazyimport
Sep 1, 2005 06:16 PM
ATS*Mark
Feb 18, 2004 01:25 PM
