Blitz SBC id boost controller questions (boost problems*help*)...
Old Sep 1, 2005 | 01:58 AM
crazyimport's Avatar
Default Blitz SBC id boost controller questions (boost problems*help*)...
What settings do you guys have set up on it ?
This is my problem.. its limiting the boost ok BUT as you can see by the graph its not constant.. its UP down UP down UP down.
Should i be checking for vacuum leaks? bad wg?
Any suggestions ?
Old Sep 1, 2005 | 11:38 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Blitz SBC id boost controller questions (boost problems*help*)... (crazyimport)
it looks like my boost logs that i have been doing with my profec b, its just keeping it as steady as it can, it will never be a perfectly flat line, so imo it is working correctly and looks to be at a solid 10psi
Old Sep 1, 2005 | 02:43 PM
BoostedCivicSedan's Avatar
Default Re: Blitz SBC id boost controller questions (coptzer)
The spike in the beginning is caused by running too much gain, which I believe can also be the cause of the inconsistency of the boost... On both my SBC-id, and my datalogs, the boost looks alot smoother than that... I will have to check to see what my settings are and get back to you... Hopefully I can help some...
Old Sep 1, 2005 | 06:16 PM
Default Re: Blitz SBC id boost controller questions (BoostedCivicSedan)
yes give me your settings please taht would help haha
ATS*Mark
Feb 18, 2004 01:25 PM
_Shadow_
Nov 23, 2001 11:16 AM
