boost dropping off
Old Apr 15, 2005 | 03:00 PM
crispydee's Avatar
Default boost dropping off
Last week i could hear a boost leak so i found the problem and sorted it and every thing is fine, until today i notice its not holding bost till the red line. Even with the leak last week it did but now it holds 0.6 bar from 3500 upto 6000 then starts dropping and ends up 0.52 ish at 8000.
The turbo is a T3 super 60 on a built B16
Going to have a look tomorrow so can anyone point me in the right direction? Its sounds like a boost leak again but it holds boost for 2500rmps and also the turbo does not sound like its spooling any faster to try and make up for a leak.
Old Apr 15, 2005 | 06:54 PM
oxSLEEPERxo's Avatar
Default Re: boost dropping off (crispydee)
it might be a small leak, just check all the piping and clamps
Old Apr 17, 2005 | 09:31 PM
crispydee's Avatar
Default Re: boost dropping off (oxSLEEPERxo)
OK, i checked for leaks yesterday, there arnt any. So any other ideas? I've got an internal waste gate could it be that?
Old Apr 17, 2005 | 10:42 PM
erau_pilot's Avatar
sounds like a blown gasket
Old Apr 18, 2005 | 03:35 AM
crispydee's Avatar
Default Re: (erau_pilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erau_pilot &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a blown gasket</TD></TR></TABLE>
Which one??
Old Apr 18, 2005 | 10:21 AM
92HB_HB's Avatar
Default Re: (crispydee)
had the same prob w/ my setup.. my boost would drop off rather quickly if it let off the throttle slightly and b/w shifts.. my car also felt weaker too.. i double checked the piping clamps and couldn't figure it out..
low and behold, I happened to check my WG bolts and the bolts holding the WG to my manifold had worked itself half way out and was leaking from there.. even from the slightest crack or hole, you'd be suprised how much it affects the car.. the bolt siezed up in the hole, so I had to drill it out and retap it.. after all the work, my car pulls hard again like before..
93b20z
Feb 27, 2009 08:14 AM
T4HATCH
Aug 25, 2006 07:23 PM
boost fed ls
Aug 31, 2004 02:02 PM
Nextelbuddy
Jun 15, 2004 07:57 AM
honkey2fly
May 15, 2004 10:32 AM
