Boost Reading, no boost
Old Feb 27, 2009 | 08:06 AM
93b20z's Avatar
Default Boost Reading, no boost
heres the problem, i had recently took off the manifold to get welded because it cracked
i then installed it back on with the old gaskets and now its not boosting... that pull at boost..
i get a boost reading...
my question is that.. can a exhaust leak from a gasket cause that??... wastegate??.. manifold to turbine??... can a dump pipe gasket cause that???
and where can i find cheap gaskets for t3t4/t04e..
anything will help if it leads to solve the problem
Old Feb 27, 2009 | 08:14 AM
Ls_dx's Avatar
Default Re: Boost Reading, no boost
Yeah It sounds like you have a leak somewhere. Have you pressure tested the system?
z6dxej1
Apr 12, 2012 03:40 AM
stunnerone23
Sep 1, 2008 03:34 PM
RFd15bhatch
Jun 1, 2005 03:35 PM
93TurboSi
Oct 16, 2003 06:04 PM
boosted hybrid
Nov 3, 2002 06:13 PM
