boost creep...to a high point
Old Sep 29, 2005 | 07:11 PM
PooOnMyShoe942's Avatar
Default boost creep...to a high point
PROBLEM::
my boost will creep to over twice the wastegate spring....its fine till aboiut 5000rpms then it creeps slowly to 16psi by 8000rpm but i only have a 7psi spring
ATTEMPT TO FIX::
1.) had all my vacuums coming from one source being the fpr...took the bov off and used the charcoal box line for the bov...didnt do a thing besides faster response from bov...
2.) turned the boost controler down to 7psi...did nothing
3.) turned off boost controler to run off the 7psi spring...did nothing
4.) unpluged the vacuum line form top of wastegate...did nothing
SETUP::
stock internal b18c
peakboost turbo kit
38mm tial wastegate
full 3 inch exhaust
greddy profec-b spec-2
Old Sep 29, 2005 | 08:40 PM
Si Shane's Avatar
Default Re: boost creep...to a high point (PooOnMyShoe942)
Run the wastegate to the first charge pipe or directly off of the compressor housing. If you must, run a direct line off of the brake booster to the wastegate. Only the wastegate should be coming from the brake booster line. Dont put many actuators on one connection, use one actuator/connection.
and what are you tuned with? What map sensor do you have?
Modified by Si Shane at 9:56 PM 9/29/2005
Old Sep 30, 2005 | 01:42 PM
Default Re: boost creep...to a high point (Si Shane)
ill try that thanks
im tuned with uberdata with the oem map sensor
Old Sep 30, 2005 | 01:44 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PooOnMyShoe942 &raquo;</TD></TR><TR><TD CLASS="quote">
your pressure source is supposed to be from the side port of the wastegate. you leave the top port open unless you have a electronic boost controler.
Old Sep 30, 2005 | 04:50 PM
Default Re: boost creep...to a high point (non-VTEC)
i have a ebc greddy profec-b spec-2...which i mentioned above
zach1288
Jul 8, 2010 02:39 PM
98integralsB18
Jul 25, 2009 07:29 AM
turbo sol
Mar 1, 2009 08:47 AM
B18 rider
Aug 23, 2005 01:08 PM
B16CRXT
Apr 24, 2005 07:50 PM
