Boost Creep?
Old Dec 25, 2012 | 10:14 AM
  #51
h22-eg-hatch's Avatar
Default Re: Boost Creep?
Add a 3-5 lb spring.
Old Dec 29, 2012 | 05:22 AM
  #52
VTC_CiViC's Avatar
Just gonna throw a couple cents into the fire here cause I was dealing with boost creep for months on end with my wife's GSR. I tried multiple wastegates, spring combinations, cam timing, tune alterations, vacuum routing, ultimatley ended up blaming a 'supposed' FullRace ramhorn and sprung for a brand new BRMS unit along with a brand new Precision 44mm WG... same problem!! It wasn't untill I finally had a full exahust installed on the car (was open DP) that the boost controller will finally lock a target boost number and won't creep in the slightest.
Take it for what you will..
Old Dec 29, 2012 | 02:01 PM
  #53
shanebadoo's Avatar
Do you mean you had a short exhaust and installed a full one with dump tube routed into the exhaust? Or do you mean you still have open dump to atmosphere coupled with a full exhaust now??
Old Dec 30, 2012 | 03:34 PM
  #54
Steeve_Civic's Avatar
Problem solved No more boost creep
It hits always same pressure. 12.2Psi for 11.8 springs
Old Jan 2, 2013 | 06:38 AM
  #55
VTC_CiViC's Avatar
I mean I had no exahust, open DP just after the oil pan, WG is still open dump, but for whatever reason, the WG could not bleed enough energy to prevent loss of pressure control above ~7k rpm.
Old Jan 2, 2013 | 09:52 AM
  #56
quick_ls's Avatar
the extra gate solved the problem?
Old Jan 2, 2013 | 12:41 PM
  #57
Yes the 2nd Tial 44mm solved my problem.
No more boost creep.
II run always same pressure. 12.2Psi for 11.8 Tial springs
turbo_d
Jun 5, 2022 06:46 PM
94c1v1cex
Mar 4, 2008 06:53 PM
DLB1994
Jan 25, 2004 11:03 AM
Racer X
Mar 27, 2003 01:07 PM
