WG spring question
Old Dec 19, 2003 | 03:00 PM
BioXide02's Avatar
Default WG spring question
Alright.. I am a lil confused so bare with me. When you get a spring, say a 5 psi spring or what ever, and buy a boost controller. How much can you turn the boost up to? Is there a limit ?
Old Dec 19, 2003 | 09:16 PM
Muckman's Avatar
Moderator in Chief
Default Re: WG spring question (BioXide02)
Ive asked this very question. I was told about double the rate of your spring before its recommended to get a bigger spring.
Old Dec 20, 2003 | 10:29 AM
BioXide02's Avatar
Default Re: WG spring question (Muckman)
Any one eles to care to shed a lil info on this thread? Becuase when I asked a local tuner shop he said it was endless.. pretty much said you could buy a 3.5 spring and turn it up to 2 bars if you wanted to.. that threw me off.. *sigh*
Old Dec 22, 2003 | 10:16 PM
BioXide02's Avatar
Old Dec 22, 2003 | 11:41 PM
Butcher's Avatar
the WG spring is only there as a safety backup basically. If you have no other means of boost control, the spring will limit boost. A boost controller comes in by intercepting the signal to the WG, and untill the new user defined boost limit is reached at the boost controller, the WG will not open. The only thing that will limit you then is the size and ammount of airflow the turbo can handle
91integraLSVTEC
Oct 21, 2009 11:09 AM
*Boostwerks*
Apr 3, 2005 05:55 PM
TurboCoop
May 19, 2004 12:21 PM
9deuce9rr
Mar 28, 2004 12:32 PM
filetofit
Jul 23, 2002 10:42 AM
