Boost Controller - confused?
Old Apr 14, 2005 | 05:09 PM
sykotic's Avatar
Default Boost Controller - confused?
Ok, I bought a Hallman Boost Controller, I hooked it up from the wastegate to the fitting on the side of it, and hooked the bottom of it to a T that connects to the intake manifold, the other end going to another T that goes to the boost gauge and to the fuel pressure regulator. Do I have this hooked up wrong? I keep turning it up and the gauge keeps reading a little above 5 psi, I probably have done 1 full turn and still nothing, any ideas?
Old Apr 14, 2005 | 05:12 PM
dustin's Avatar
Default Re: Boost Controller - confused? (sykotic)
You have the MBC between the intake manifold and the side port on the wastegate right?
I'm not familar with the Hallman MBCs, but usually 1turn = 1psi. Sometimes you have to start with a couple turns before it will even start changing boost...
Old Apr 14, 2005 | 06:22 PM
s2kdre's Avatar
Default Re: Boost Controller - confused? (dustin)
the mbc goes inline with the wg and turbo. the bottom goes to the turbo and the side port to the wg.
bigred850
Oct 9, 2011 05:34 AM
99silverbullet
Jan 3, 2004 06:28 PM
redhatchb18
Oct 7, 2003 02:26 PM
Cowboy
Jun 16, 2003 02:12 PM
echo999
Oct 1, 2002 07:41 PM
