Boost controller badkward?
Old Apr 14, 2014 | 06:37 PM
Kid-jdm-teggy's Avatar
Default Boost controller badkward?
Is my boost controller hooked up backward? The line on the left is coming from the boost source and the one on the right is going to the wastegate. Or should it be vice versa?
Old Apr 14, 2014 | 06:42 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Boost controller badkward?
Yes, it's backwards.
Old Apr 14, 2014 | 06:47 PM
wantboost's Avatar
Who is Mr Robot?
Yup backwards. just FYI there's a reason that arrow is pointing towards the controller, that means pressure source inlet
Old Apr 14, 2014 | 06:52 PM
Ok thanks guys, and the **** says turning it counterclock wise "boost (-)" and turning it clockwise "boost (+) but when i turn the boost down following the **** (boost -) the **** is going deeper into the controller which means its increasing the boost due to the spring inside being stiffer? If so, this chinese made controller is written backward?
Old Apr 14, 2014 | 08:43 PM
Ok i guess when the **** goes in, it increases the boost. If anyone had this type of ebay one and know what kind of increments to turn up the boost 1psi will be appreciated. Some people say half a turn and others say by the clicking sound. I counted and there is 61 clicks so i dont think clicking is accurate.
Old Apr 14, 2014 | 09:20 PM
NotARaCist's Avatar
It's a cheap piece of crap. There is no guaranteed increment, because no one has any idea what spring is in there, or even if the spring has a linear or non-linear rate. If you want exact numbers, pony up the money for a real electronic boost controller. If you want to keep using that thing, find a track or an open parking lot somewhere that you can fiddle with it, but don't be surprised if you have to fiddle with it every time there's a fluctuation in the temperature.
ericstambaugh07
Jun 23, 2007 09:04 AM
ATS*Mark
Feb 18, 2004 01:25 PM
Meet07
Feb 3, 2004 10:45 PM
echo999
Oct 3, 2002 07:41 PM
